I dont see an option for the 2008 dodge charger on the lx platform I see an option for 2008 300 on lx' so how would I use it on 2008 lx charger.
The clusters have a two part bezel, inner and outer, the other bits are pretty much the same. I had to swap both bezels and remove the outer rings from the gauge faces since they protrude out a bit, I could have removed a little from the charger bezel and got it to work but I was in a time crunch. From what I can tell I only lost the ability to see gearing when in autostick, the cluster doesn't understand that code so it goes blank, also the Chrysler only has a 140 or 160 speedo, I bought a 260 kph from Canada I always use the digital speedo anyway so don't care.
Air Bags for people that understand the difference
Use 300.
Same architecture. Alfa will read your BCM and display useable options.
Bob
http://www.luxte.ch
Lux Technologies
The only thing in alfaOBD for 2008-10 is Non-Powernet Central Gateway Module. Unsure of what can be changed. It does show similar options as 2011 but I do not recall LX bodies having SRT pages and such so not sure what all you can do there.
Any BCM options are 2011 + only.
This is from looking directly at my alfaOBD
2011 Dodge Charger Pursuit 113K Miles. Stock for Now.
Cop Brakes, Cop Exhaust, Cop Suspension,
It's the model with the big bull bar so pedestrians get out of the way.
2011 will not have Sport Mode or Performance Pages.
2013 Dodge Charger R/T Plus, Edelbrock E-Force 2300TVS 6.4 PSI, Mustang-Dyno Tuned 418hp/430tq, 3.06:1, Severe Duty Radiator, Dual Fans, OE Oil Cooler, Pursuit BR9 Brakes, Corsa CatBack, Bilstein Dampers, Catch Can, AlfaOBD enabled Sport Mode & SRT Pages, Fogs on w/High Beams, Add Reverse Cam & Auto Dimming & Tilt in Reverse Left Door Mirror.
thanks guys for the reply, so I tried the suggestions using the alfaobd using a generic elm327, its a clear blue. The adapter works with torque app but with alfa app I choose bluetooth and it connects , then I choose the 300 and it tries to connect but never connects. It says to turn the key to the start etc.
The adapter I have elm327 v 2.1so I am thinking the problem is the adapter, but I lookked up the obxlink in canada and price is over 120 CDN, is there any other adapters that are cheaper that would work?
Unfortunately, the ELM327 is probably the worst dongle, to use with Alfa. I'm sure it is great, for other applications, but the bus speed is way to slow to connect, reliably, to the various modules. Not to mention that there is an adapter needed, when connecting to some modules, for any dongle, but the MX, or MX+. These dongles switch internally, eliminating the need for an external harness.
Yes, the MX and MX+ are expensive... but a dealer re-flash might cost even more.
Bob
Hi all, , first, sorry for my poor english (i'm french) . I'm looking for a way to activate launch control on a 2012 Chrysler 300 . Did someone have the same car ( year 2013 , 2014) and can give me is Alfa report. I wouls like to see the Chassis number , i read in an another post that was the way to activate Launch control in some car , so i like to try. I know there's a BST to add this Launch control for 2012 models but no dealer can do that in France.
