Results 1 to 15 of 20
    Apr 2018
    Are any of the stock batteries AGM?
    Does anyone know if the stock Mopar batteries are AGM? I'm putting mine on a tender while it's in storage and it has an AGM mode. The battery I have is a BB0H7730AB. I can't find anything online about it being an AGM so I'm guessing it's not but I figured I'd ask!
    2017 Pitch Black Charger Scat Pack 392
    20% tint, Billet Technologies Matte Black Catch Can, LED interior lighting, ZL1 Rock Guards, K&N drop in filter, MaxBeam Smoked LED side markers
    Mar 2016
    Does it have vents on the top?
    Mar 2017
    Bedford, Texas
    It is not an AGM battery. There's a vent line that hooks to it to let the vapors out of the cars.
    Thanks Dextar thanked for this post
    Likes Dextar liked this post
    Braintree, Massachusetts
    Exclamation
    The Police cars use a larger CCA battery which is an AGM Battery. Otherwise, they have a conventional battery. And whether it has an AGM Battery or not, an LX battery has a vent tube.
    2017 Dodge Charger R/T Scat Pack - Go Mango
    Jan 2011
    Porter Ranch, CA
    AGM batteries for our cars also have vent tubes. That is not a determining factor.
    2016 Charger SRT TorRed Best: ET 12.70, MPH 112.30 (DA 2446ft.), 60ft. (1.95 radials) BBK 85mm, AFE CAI, Johan 91Oct tune. 1/2 Mile: 135.38mph, 1 Mile: 160.0mph; 1.5 mile 170 (let off to avoid breaking out of 170 class)
    2008 Caliber SRT4 Inferno Red - SOLD [email protected] (2.327 60 ft.) MS1K v.2, MPx catted DP, K&N drop-in, NGK plugs, RT 180, Mopar hitch, new short block @ 82,000
    2007 300C SRT8 Inferno Red - SOLD [email protected] (2.003 60 ft.) AFE CAI, Predator 93 CAI, Magnaflow gutted high-flow cats, Stack intake spacer, BBK 85mm TB, JET 188, Proxes 4 275/40ZR20
    Feb 2018
    Boca Raton, fl
    AGM, AGM tender
    2013 Chrysler 300S, 6.4 BGE with 6.4 SRT cam, AIT 18% OD pulley, E-force with 2.75 pulley, fastman 84+4 mm throttle body, 1 7/8 kooks long tubes w/hi-flow cats, Magnaflow Cat-back, FTI 2800 stall, Trans built by Hellraiser, Dings Racing valve body and tune, Getrag 3.73, Walbro 400LPH, DW 65# inj. LG aluminum rad. Dual SRT fans. Complete 4 piston Brembo upgrade.
    XIX X39 22x9 - 22x10.5 with NITTO 420 275/40R22 +15 - 295/30R22 +22
    Jul 2017
    I bought a replacement AGM battery from Autozone after my original battery died, it does not have vent a tube.
    Feb 2012
    Houston TX
    Quote Originally Posted by PurpleCat16 View Post
    That's a little concerning. Are you 100% sure there's not a hole anywhere on the top edge of the casing where a vent nipple and hose could be installed? AGM batteries can vent, generally not expected unless you get into an overcharge situation, but in the event of that I would not want it venting into the trunk compartment.
    Richard
    Feb 2018
    Boca Raton, fl
    Any battery inside car has a vent to outside, my AGHM from Autozone had the port for vent. It's not a nipple sticking out, but a plug you pull out and insert the vent hose.
    Jan 2011
    Porter Ranch, CA
    My AGM from Autozone also had a vent tube. If you don't have one, then you were given the wrong battery for your car.
    Jul 2017
    There is no provision to install the factory vent tube, I am not concerned with overcharging as I do not drive the car regularly, I am more concerned with the lack of discharge charge cycles, not so much now that I have a battery tender with an AGM setting. This Autozone AGM battery is also 880 CCA, where the stock Lead Acid battery is only 770 CCA.
    Jul 2017
    Autozone only has 1 AGM Battery for the Challenger Hellcat and it has no provision for a drain tube.
    Fits Your Vehicle Duralast Platinum Battery
    Price: $194.99
    Core $18.00
    Feb 2018
    Boca Raton, fl
    Price: $194.99
    Core $18.00
    You need to look at pics again, there is a port (side, top, middle, pull plug, insert tube.
    Mar 2016
    It doesnt not need to be "vehicle specific" battery. Just needs to be the same group size and amp rating you want. That battery above is group 94r. Google that and find the battery you want.
    Feb 2017
    glendale az
    copied and pasted out of service info for a 2016 challenger (LA) 5.7
    08 - Electrical / 8F - Engine Systems / Battery System / Description DESCRIPTION
    This vehicle is equipped with a single 12 volt Absorbed Glass Mat (AGM) battery. All of the components of the battery system are located within the trunk compartment of the vehicle. The battery system for this vehicle contains the following components:
    • Battery - The storage battery provides a reliable means of storing a renewable source of electrical energy within the vehicle.
    • Battery Cables - The battery cables connect the positive and negative charged battery terminal posts to the vehicle electrical system.
    • Battery Holddown - The battery holddown hardware secures the battery in the battery tray.
    • Battery Tray - The battery tray provides a secure mounting location in the vehicle for the battery and an anchor point for the battery holddown hardware.
    • Intelligent Battery Sensor- The Intelligent Battery Sensor (IBS) serves to record and process measured battery variable values (current, voltage, temperature) for the vehicle powernet management system.
