Page 2 of 2 FirstFirst 12
Results 16 to 19 of 19
  1. #16
    Calgary, Alberta
    Why all the hub-bub for AGM? Do folks understand the plus and minuses of AGM vs. flooded cell?
  2. #17
    Feb 2012
    Houston TX
    Definitely interested in hearing from you on this subject. I've got an AGM from Odyssey in my truck though it doesn't make much sense as I drive it almost daily, for a 45 min to 1 hr trip each way. It has lots of opportunity to stay charged and no sitting around to discharge.. So any benefit I might have realized is negated.
    On the other hand, the 300 might not move for 2 weeks at a time, just hiding out in the garage. It's got a regular battery though it doesn't seem to sit long enough to notice any weakness from running down.
    Richard
  3. #18
    Mar 2016
    Lithium ftw
  4. #19
    Feb 2017
    glendale az
    Main reason more models are going to agm batteries is due to gassing, we are moving more batteries into passenger compartments and agm batteries put off little to no gassing under normal circumstances. Batteries generally fair better in a more favorable temperature range such as the climate controlled passenger area.
