Results 1 to 15 of 15
Thread: Tazer issue
    Jun 2018
    Pleasanton CA
    Cool Tazer issue
    Ok I installed my tazer and not my back up camera isn't working. Did I mess up a setting? If so what? I tried resetting everything but I don't think I did it right because nothing but splash screens changed.////SOLVED!!!////I followed a settings video provided by another member and i noticed that in the "Pref" option the setting 5speed option was set to off. Once i changed it to on i was able to conduct a proper reset and regain camera functions.
    Jul 2011
    Jarrell, TX
    Did you marry the Tazer to the car as that function makes a backup. This allows you to do a 1 touch restore.
    Sent via Tapatalk
    My Scat Pack Web Site
    May 2016
    Chelsea Alabama
    Quote Originally Posted by BlackBeauty392 View Post
    Ok I installed my tazer and not my back up camera isn't working. Did I mess up a setting? If so what? I tried resetting everything but I dont think I did it right because nothing but splash screens changed.
    We need more info. What year is your car and how did you "install" it?
    Jun 2018
    Pleasanton CA
    It's a 2018 charger SP. I used the bypass and its placed in the trunk.
    May 2016
    Chelsea Alabama
    Ok. You have to do this after any setting change for 2018’s. Made a video of it
    Tazer Full reboot procedure for 2018 dodge chargers. ✔️ - YouTube
    Jun 2018
    Pleasanton CA
    Did that 2 times.
    May 2016
    Chelsea Alabama
    Tazer issue
    Did that 2 times.
    The entire thing including disconnecting the radio fuse? Where you able to marry your car, access the tazer menus and make changes?
    Jun 2018
    Pleasanton CA
    If I un marry it shouldn't it restore to oem?
    May 2016
    Chelsea Alabama
    Yes. What things did you change. I have a video saying everything I changed on my 2018. I can share that with you if it may help ya out.
    Jun 2018
    Pleasanton CA
    Its Married- I pulled the fuse like the video said to. I even unplugged the tazer and went into u connect and reset all settings with no results..can I just pull the battery for a while and let it reset that way?
    Jun 2018
    Pleasanton CA
    Only thing I've changed was adding eco, srt stuff,remapped sport button. I'll try manually resetting everything and see what happens.
    May 2016
    Chelsea Alabama
    Ok. I know if you don’t get all the settings changed correctly for the SRT stuff they won’t work. This shows all my current settings and how to get to each on a walk trough of the menu’s. It may help, you may have missed something.
    My Tazer settings and how to set them on firmware 2.4.3 on my 2018 Scatpack Charger. ✔️ - YouTube
    Jun 2018
    Pleasanton CA
    Thanks! Ill give this a shot when im of work in the morning (7am Cali time). I let you know the results!
    Jun 2018
    Pleasanton CA
    I managed to sneak out to my car and I noticed that under performance 5speed perf was turned off. I turned it back on and I was able to do a reboot and it worked. Now if only I can get Nav in motion working I'll be in business. I haven't driven it yet with what seems to everything working but fingers crossed.
    May 2016
    Chelsea Alabama
    I actually talked to Zauto on the nav in motion and it doesn't work in the 18's for some reason. They are working on it. Glad i could help man!
