Car wont start?
23K views 32 replies 9 participants last post by  mattlemire73
#1 ·
2012 challenger rt with some mods d1sc blower cam 6.1 intake try to start it and it will not replaced battery and starter so far and same issue. Any ideas solutions?
Sent from my LG-LS993 using Scat Pack Forums mobile app
#10 ·
I have been driving it daily i went into a sprint store after a 15 mile drive where car ran fine with no. Issue and it had never shown any issue of this sort before i went in to store car would start no problem came out car would not start. So i replaced battery right then and had to be towed. To a shpp where i had starter replaced and it still wont start and they. Want 200 a hr to diagnose
#11 · (Edited)
Can you have someone take a video of the engine bay when you try to start it?
Did you try the hand crank as suggested?
#22 · (Edited)
From 2006 LX Service Manual (You might try to download the one for your year. I'm not sure if the troubleshooting is different). Can you tell if the starter is trying to engage?
STARTER FAILS
TO ENGAGE.
1. BATTERY
DISCHARGED OR
FAULTY.
2. STARTING CIRCUIT
WIRING FAULTY.
3. STARTER RELAY
FAULTY.
4. IGNITION SWITCH
FAULTY.
5. PARK/NEUTRAL
POSITION SWITCH
(AUTO TRANS) FAULTY
OR MIS-ADJUSTED.
6. CLUTCH INTERLOCK
SWITCH (MAN TRANS)
FAULTY.
7. STARTER SOLENOID
FAULTY.
8. STARTER ASSEMBLY
FAULTY.
9. FAULTY TEETH ON
RING GEAR.
10. PCM DOUBLE
START OVERRIDE
OUTPUT FAILURE.
1. REFER TO THE BATTERY SECTION FOR MORE
INFORMATION. CHARGE OR REPLACE BATTERY, IF
REQUIRED.
2. REFER TO FEED CIRCUIT RESISTANCE TEST AND FEED
CIRCUIT TEST IN THIS SECTION.
3. REFER TO RELAY TEST, IN THIS SECTION. REPLACE
RELAY, IF NECESSARY.
4. REFER TO IGNITION SWITCH TEST, IN THE STEERING
SECTION OR 8 WIRING DIAGRAMS. REPLACE SWITCH, IF
NECESSARY.
5. REFER PARK/NEUTRAL POSITION SWITCH TEST, IN THE
TRANSAXLE. SECTION FOR MORE INFORMATION. REPLACE
SWITCH, IF NECESSARY.
6. REFER TO CLUTCH PEDAL POSITION SWITCH TEST, IN
THE CLUTCH. SECTION. REPLACE SWITCH, IF NECESSARY.
7. REFER TO SOLENOID TEST, IN THIS SECTION. REPLACE
STARTER ASSEMBLY, IF NECESSARY.
8. IF ALL OTHER STARTING SYSTEM COMPONENTS AND
CIRCUITS CHECK OK, REPLACE STARTER ASSEMBLY.
9. ROTATE FLYWHEEL 360°, AND INSPECT TEETH AND RING
GEAR REPLACED IF DAMAGED.
10. REFER TO PCM DIAGNOSTIC. CHECK FOR CONTINUITY
BETWEEN PCM AND TERMINAL 85. REPAIR OPEN CIRCUIT
AS REQUIRED. IF OK, PCM MAY BE DEFECTIVE.
STARTER
ENGAGES,
FAILS TO TURN
ENGINE.
1. BATTERY
DISCHARGED OR
FAULTY.
2. STARTING CIRCUIT
WIRING FAULTY.
3. STARTER ASSEMBLY
FAULTY.
4. ENGINE SEIZED.
5. LOOSE
CONNECTION AT
BATTERY, PDC,
STARTER, OR ENGINE
GROUND.
6. FAULTY TEETH ON
RING GEAR.
INFORMATION. CHARGE OR REPLACE BATTERY AS
NECESSARY.
2. REFER TO THE FEED CIRCUIT RESISTANCE TEST AND
THE FEED CIRCUIT TEST IN THIS SECTION. REPAIR AS
NECESSARY.
3. IF ALL OTHER STARTING SYSTEM COMPONENTS AND
4. REFER TO THE ENGINE SECTION, FOR DIAGNOSTIC AND
SERVICE PROCEDURES.
5. INSPECT FOR LOOSE CONNECTIONS.
6. ROTATE FLYWHEEL 360°, ANDGEAR REPLACED IF DAMAGED.
Reactions: KYUUBI
#26 · (Edited)
That other guys's was obviously not seized. It's interesting his would start when he threw it into neutral sometimes (park/neutral switch on his maybe??). You might try that when you get it. Also actuating the clutch a bunch on yours might point you to that switch quickly. Other than that, I'd just step by step through the service manual possibilities and rule those out one by one using their tests.
2007 Charger R/T, Supercharged
#25 ·
Have you been able to turn the motor over by hand yet? What made you think it was the Battery or Starter? Look every hose and wire over well and make sure nothing came loose or got to close to heat and melted. Could be as simple has a ground too. Also if you thought it was the Battery or Starter. It wouldn't be the first time someone bought a new one and it was bad from the Store. Is it not throwing any codes either?
#28 ·
I have not yet had a chance to get to my car since i had it towed and had new starter put on im having it towed today home Dave from fixer who. Did all the big mods on the car is going to visit his mother in a area not to far from me i believe hes locatec in ft Myers im in the villages area and hes making a put stop by on his way home sunday he would be alot more knowledgeable on what my be the issue i was told it might be a neutral type sensor and i think i do need to check some wires as far as possabily burnt of heat damaged ...i will post more info on this sunday evening
#31 ·
Did you Fix this?
