Page 3 of 4 FirstFirst 1234 LastLast
Results 31 to 45 of 48
  1. #31
    Corona, CA
    The vid in post 17 shows it
    Yea... I know.
    Just all the other posts were only referring to the one on the drivers side...
    2006 Charger SRT8
    MPR Motorsports built 6.1 based/392 NA Stroker, BBK 85mm TB, TranZformer, Kooks Long Tubes, 3.70 LSD Hellcat rear cradle
  2. #32
    Jan 2019
    One thing- if the smaller diameter high pressure line is hot- and the bigger diameter low side line is cold- the evap must be getting cold.
    Yep this is what’s happening
  3. #33
    Jan 2019
    This you can do also. Under dash on drivers side. Remove the lower silencer pad. You will see actuators that control drivers blend air door- depending on dual zone or not. Adjust heat on drivers side and you should see actuator moving door. I will look at mine today at work.
    I will check this out! Thanks
  4. #34
    Sep 2018
    Springfield, MO
    Quote Originally Posted by reefstar View Post
    Well, the automatic Temp control, you just set the temp, and it controls everything automatically.
    If you have a knob the goes from blue to red when you turn it, you have manual.
    Since you don’t know what automatic is, you probably have manual.
    Also four knobs on the console for air is auto, 3 is manual.
    Thanks pursuitlx thanked for this post
  5. #35
    Jun 2018
    I do HVAC for a living Just because it’s in a car the principles are the same the pressures do not lie your evap cool is 40 degrees you have blend door issues them being stuck or the control being messed up that is the issue.
    This is beating a dead horse.
    Thanks Ultimagic5 thanked for this post
    Likes reefstar, Ultimagic5 liked this post
  6. #36
    Oct 2010
    Eastern WA
    Riddle Me This AC Fans
    Quote Originally Posted by DaBlackBomb View Post
    Take it back to the shop and tell them to calibrate the blend doors (and maybe a refund).
    Any certified tech should have started there.
  7. #37
    Jan 2020
    Haven't I seen a lot of threads around the net about the blend doors failing on these cars?
    I know the recirc door was designed by a drunk chimp with his finger in a light socket.
    Likes Ultimagic5 liked this post
  8. #38
    Jan 2019
    Yes door actuators do move
  9. #39
    Jan 2019
    i think you’re right if that winds up what it is.
    Thanks reefstar thanked for this post
    Likes reefstar liked this post
  10. #40
    Oct 2010
    Eastern WA
    They can check and reset the blend doors with the DRB. Sometimes they get uncalibrated and they need to be reset.
  11. #41
    Oct 2010
    NJ
    If you have a cabin air filter make sure it's clean. This will affect airflow at the evap.
    Sent from my SM-G955U using Tapatalk
  12. #42
    Oct 2010
    Eastern WA
    Quote Originally Posted by hd7585 View Post
    That’s possible, but he would get cold air (albeit slow moving air) until the evaporator iced up.
  13. #43
    Jan 2019
    Recirc door stuck on fresh air.
    Send me your PayPal
  14. #44
    Jun 2018
    Send me your PayPal
    Hahahaha hmmm a stuck door how bout that
  15. #45
    Jan 2019
    Quote Originally Posted by Eric40962005 View Post
