Page 2 of 4 FirstFirst 1234 LastLast
Results 16 to 30 of 48
  1. #16
    Jan 2019
    Quote Originally Posted by ChuckWagon View Post
    When is the last time you cycled the temps on both sides to full hot, then full cold? My car needs to have this done occasionally and it is cheap to try. Try doing it a couple times, slowly, and see what you get.
    Ok i will try it
  2. #17
    Feb 2018
    Boca Raton, fl
    Newer vehicle. 2013 Dodge Charger SXT actuators and blend doors acting stupid - YouTube a blend door that affects both sides?
    Also, does your recir function normal, light comes on, stays on, fans increase?
    13 Chrysler 300S, Stock 17 RAM 6.4 BGE with TSP Stage 4 boosted Cam, AIT 18% OD pulley, E-force 2.62 pulley(12.2 lbs boost),, Fastman 84+4 mm throttle body, 1 7/8 kooks long tubes w/hi-flow cats, 3" Magnaflow Cat-back, FTI 2800 stall, Trans by Hellraiser, Dings Racing valve body and tune, Getrag 3.73, Walbro 400LPH, DW 65# inj. aluminum rad. SRT fans. Brembo upgrade. Stage one MOPAR springs, XIX X39 22x9 +15 - 22x10.5 +22 with NITTO NT555 265/35R22 - 295/30R22
  3. #18
    Jan 2019
    m
    yes recirc light comes on and stays on. I don’t know if fansnincrease during recirc. U mean condensor/rad fans? I’ll check if they increase when recirc is put on
  4. #19
    Feb 2018
    Boca Raton, fl
    Quote Originally Posted by DaBlackBomb View Post
    m
    Usually an increase in blower motor speed.
  5. #20
    Jan 2019
    Ok I will check
  6. #21
    Jan 2019
    How do I know if my
    car has atc or mtc?
  7. #22
    Oct 2010
    Eastern WA
    How do I know if my
    car has atc or mtc?
    Do you have automatic temperature control (atc), or manual temperature control (mtc)?
  8. #23
    Jan 2019
    Ok i will try it
    Seems to work ok. Both stay on the cooler side as I turn the knobs to heat but around 3/4 all the way to full heat u feel the heat come on.
  9. #24
    Jan 2019
    Unhappy
    Quote Originally Posted by reefstar View Post
    How Can I out and check?
  10. #25
    Oct 2010
    Eastern WA
    Well, the automatic Temp control, you just set the temp, and it controls everything automatically.
    If you have a knob the goes from blue to red when you turn it, you have manual.
    Since you don’t know what automatic is, you probably have manual.
  11. #26
    Jan 2019
    Yep manual it is
    Likes reefstar liked this post
  12. #27
    Jan 2016
    One thing- if the smaller diameter high pressure line is hot- and the bigger diameter low side line is cold- the evap must be getting cold.
  13. #28
    Jan 2016
    This you can do also. Under dash on drivers side. Remove the lower silencer pad. You will see actuators that control drivers blend air door- depending on dual zone or not. Adjust heat on drivers side and you should see actuator moving door. I will look at mine today at work.
  14. #29
    Corona, CA
    There is a blend door actuator on the passenger side also...
    2006 Charger SRT8
    MPR Motorsports built 6.1 based/392 NA Stroker, BBK 85mm TB, TranZformer, Kooks Long Tubes, 3.70 LSD Hellcat rear cradle
  15. #30
    Feb 2018
    Boca Raton, fl
    Quote Originally Posted by netnathan View Post
    The vid in post 17 shows it
