Page 3 of 14 FirstFirst 1234513 ... LastLast
Results 31 to 45 of 199
  1. #31
    Oct 2010
    Eastern WA
    MAP sensor relocated. I put it where the EGR port used to be. That’ll be a few less wires as well running over the heads. Just need to finger mold it in with epoxy and should be good.
  2. #32
    Jan 2020
    What product are you using that will actually bond to that plastic? I've tried several with never a good bond. I'd love to have a working bond in my back pocket for the next time I have to fix something. TYIA
  3. #33
    Oct 2010
    Eastern WA
    Quote Originally Posted by doublechaz View Post
    Are you trying to glue something to it, or do a “repair” like a crack or fix a hole?
  4. #34
    Jan 2020
    Repairs of broken off sections generally.
  5. #35
    Oct 2010
    Eastern WA
    My 3.5L EPIC waste of time!!! Why not!
    There’s the wiring harness for the Viper Throttle Body (and one of our Corgis that hopes it’s a treat)
    I’m going to be doing some research on pre ‘96 3.5L pistons. I’m so close... so, why not pull the block and bump it up to 10.4:1 compression??? If they end up being drop in pistons.... I think I have to do it. Do I?
  6. #36
    Oct 2010
    Eastern WA
    The hard think with things that are broken off, is that by their very nature they are susceptible to break off again.
    First you always want a clean surface. Use a stainless steel wire brush and a piece of 200 grit sand paper. And scuff everything that is going to be glued
    I used JB plastic weld. Once you epoxy the piece in place. Use tape or something to hold it in place. Keep it tight, and don’t let it move for at least 12 to 24 hrs. Leave it alone.
    Then if needed go back and build it up with more epoxy. You can also use a plastic welding kit as well.
  7. #37
    Oct 2010
    Eastern WA
    Who else HATES this thing. That stupid transmission fill tube holder.
    This is the way it should have been done in the first place!
    BEFORE
    AFTER
  8. #38
    Oct 2010
    Eastern WA
    Next Step.... Very very important!!!
  9. #39
    Jacksonville, FL
    As long as the epoxy is adhering to the needed surfaces, you can use fiberglass cloth for additional strength.
    This was a method used in high power rocketry for securing fins to the body.
    Terry
    2019 Octane Red Charger GT
    2020 Charger Scat Pack Widebody
    Likes reefstar liked this post
  10. #40
    Oct 2010
    Eastern WA
    Quote Originally Posted by RT NOMAD View Post
    Fiberglass resin should work well too if you can get adhesion. You can add fiber to it.
  11. #41
    Jul 2019
    Southern California
    Quote Originally Posted by reefstar View Post
    Have I ever owned a modern day Hemi?
    I’ll do you one better, my brother in law was the first certified Viper Tech in California. So, I’m very aware of Power.
    Do you know that one of Dodge’s biggest customer complaints about the Viper was “extreme rear tire wear”.
    I don't appreciate just any build simply because I like cars, nor have I seen anybody's Gen 3 Hemi sticking out of the hood. What I do like about what you're doing though is that it's unique, it's something different with different goals in mind. Not something I'd do, but that's why it's unique!
    However these quoted lines had me rolling...."No I don't have a fast hemi car, but I know a guy who worked on someone else's V10 that was fast, so I know what it's like to own a fast car, and someone else didn't like having to buy rear tires so I know I don't want power". Rofl.
    Good luck on your build, it definitely looks nice, and good choice on the cigar. Love the Acids
    2005 300C 5.7 Cool Vanilla - CAI, Diablosport, Cat Back, MSD Coils/Wires
  12. #42
    Oct 2010
    Eastern WA
    Quote Originally Posted by chopperscfl View Post
    Funny! I appreciate everything you said. It was very unique. But what I didn’t appreciate was that you quoted me as saying something I didn’t say. (See, I did the same thing you did there)
    If you want to “interpret” what you think I said, fine... but you shouldn’t put quotations marks around it. It’s a bit defamatory. Not sure I be seen a wrench in your hand yet. I’d love to see your build! Better yet, if your not sure what I mean, just ask me, and I did go on to say that I currently own a truck with a Hemi in it.
    Anyway, yeah... always need a good selection of ACIDS in the humidor. Also makes the garage smell great.
  13. #43
    Oct 2010
    Eastern WA
    Ok... so appaaaaaarently Mopar went to a smaller piston pin in ‘07 which would make changing out pistons a lot more involved, buuuuuut, I happen to have an ‘05 so the pins are the same size.
    Looks like I need a cherry picker, and an engine stand (and a more organized garage for space) And we’re bumping her up to 10.4 to 1 compression. My 3.5L EPIC waste of time!!!  Why not!
  14. #44
    Oct 2010
    Eastern WA
    Viper Throttle Body arrived.
  15. #45
    Jacksonville, FL
    Are you concerned that the Viper throttle body might be too large for your 3.5L?
    Did you say what injectors you were using?
