Originally Posted by
reefstar
Thanks for the comments. Here’s my thinking behind the exhaust, (BTW I build performance motorcycle systems).
The 3.5 is a 1-2-3-4-5-6 firing order. So the pulses alternate banks evenly. So, I kept the x over installed in the system. So scavenging at the x over should function well (it did before I did the engine work) especially with the new headers. Also I am keeping the mufflers installed (because it’s a 300, and I want a comfortable ride). If I eliminated the mufflers, I think you’d be right on point.
I also believe that the engine is very restricted at the throttle body (they a boring the 3.6L out to 80mm). So with the new 74mm TB and intake plenum updates, I’ll be moving more air than I was before the build.
Also, the exhaust still has the valves behind the mufflers, so if I’m getting too much flow through both pipes, I can adjust the tension on the valves to keep one side closed until it reaches high rpm.
Anyway, thanks for the comments and input, I appreciate it!
I can't see how an 80 mm TB will help on a 3.6 or that you're moving MORE air. Internal combustion engines are just big air pumps and can only process just so much air, based on the displacement. The 5.7's and 6.1's come stock with 80 mm TB's and they're just about right for their displacements. As far as "moving more air" goes, you won't be moving MORE air, but you'll be moving it more efficiently because the Voumetric Efficiency (VE) of your engine will be a little higher than before. Again, with forced induction, everything changes in this regard.
On the 5.7 side of things, at 100% VE, this displacement is capable for processing 658.275 CFM of air. Most "stock" vehicles usually have a VE of somewhere around 70-80% which means less than 450-500 CFM is processed. Bottom line, going bigger is not always better. When everything is set up to match the displacement, more power is generated. To give you an idea, I pulled the heads on both of my early 5.7's to have new valve seats installed (dropped valve seat problems with the early 5.7's) and, while I was at it I had the heads ported and polished and .030 in. milled off them to raise the compression ratio by about a half point. Since the 5.7's heads flow pretty well in stock form (on a relatively stock engine), both of these mods. combined netted only somewhere around 25-30 horsepower. IMO, the gainse were not hardly worth the $$$$ for a daily driver, and I probably wouldn't do the port/polish again...I'd probably still mill them though.
06 300CSRT8, Comp cammed, 85mm TB, HP/DS Tuners, 06 Jeep GCO and 05 Magnum RT (5.7's) both modded almost the same, MDS "ON" Lt, Fumoto Drain Valves, BT Catch Cans, SRT8 CAIs, AFE Filters, Sonnax Trans Line Press Booster, SC, DS and HP Tuners, Transgo Shift Kit, ARH Long Tube Hdrs w/3 in Magnaflow/Xlerator AP Exh Sys, Bilsteins, SRT Springs/Sways, Cust Eng Cvrs, SRT8 frt/rear bumpers, advanced FRI Sidewinder Cams (Jeep 6*/Maggie 10*), 6.1 valvetrains, SLP 25% UD Pulley, BBK or Arrington 90mm T-Bodies, SOS Ign Coils,TEA ported/milled heads w/new valve seats, SRT Reps.
