Results 1 to 13 of 13
Thread: AC help needed
    Jan 2019
    AC help needed
    2007 charger rt
    So I replaced the evap core cause it was leaking, the drier, and compressor is about a year old.
    At 90 degrees outside I got:
    low and high at 101 psi static
    55 low and 255 high with compressor on and system on highest cooling
    at 1500 rpm low was 32 and high stayed at 255
    so...temp out of vents won’t get colder than 70degrees. Before evap
    replacement it was around 55 deg.
    So I’m thinking obstruction on high side?
    Could a bad blend door do it?
    Mar 2017
    Bedford, Texas
    Did you pull a vacuum on the system before you recharged it?
    Jan 2019
    Angry
    yes. BUT now I’m thinking 1 1/2 hrs wasn’t enough as I did see bubbles in site glass....moisture
    Mar 2017
    Bedford, Texas
    Quote Originally Posted by DaBlackBomb View Post
    I always pull as close to 29" of vacuum as I can, turn the pump off and let it sit for about 30 min to watch the gauges and make sure there's no leaks before I recharge. Otherwise it's a waste of refrigerant.
    Jan 2019
    Yep. Did that and no leaks.
    Those pressures appear normal. I would suspect the blend door? But, I'm wild guessing here?
    Jan 2018
    Is the electric radiator fan working?
    Feb 2018
    NorCal
    Bubbles aren't always a sign of charge status, depends on the system load.
    I've had systems hold a vacuum and still leak, I attribute it to the compressor seal which will suck closed tightly under vacuum but leak under pressure.
    Jan 2019
    Quote Originally Posted by Root66 View Post
    Root66,
    can u accurately tell how much refrig is in system without emptying it
    and weighing it ? I took it somewhere and he said I was low almost 1/2 pound but he didn’t empty it.
    car still blows at 70 degrees
    Jan 2019
    Quote Originally Posted by Genestealer View Post
    Yes
    Jan 2019
    no dye leaks there or anywhere that I can find.
    only in the evaporator which is why a replaced it
    Jan 2019
    Root66,
    Anyone know?
    Feb 2018
    NorCal
    Root66,
    and weighing it ?
    No, anything else is just a guess.
