Results 1 to 10 of 10
    Oct 2019
    Initializating new abs module
    Do you have to reprogram a abs module if it’s new to your car..and is the dealership the only one that can do it?
    Sep 2018
    Springfield, MO
    I can't remember if there was an option to do anything like that with my charger or not on appcar.Might be able to do it with the app car program or alfaobd.
    Last edited by Ultimagic5; 12-02-2019 at 06:46 PM. Reason: Cuz I can't read the forum titles
    Likes Sloparjay liked this post
    Oct 2019
    2007 Dodge Charger
    Oct 2019
    Quote Originally Posted by Ultimagic5 View Post
    What model year vehicle? Might be able to do it with the app car program or alfaobd.
    2007 dodge charger
    Calgary, Alberta
    If indeed the ABS module, yes.
    Oct 2019
    Yea i swapped the abs module same serial number and all but from a different vehicle and have a few codes related to the abs module probably needing to be flashed
    Calgary, Alberta
    Note; if the HCU was also replaced it must be bled using a OBDII scan tool.
    Mar 2016
    N. GA
    I have a Foxwell NT630 that can initialize and ABS bleed. There are others as well.
    2013 Dodge Charger R/T Plus 362.63HP/389.58TQ
    Oct 2019
    Thanks gonna look into that
    Jul 2019
    A regular shop can do it with a Snap On tool, doesn't have to be the dealer.
    Likes Magnoom, Sloparjay liked this post
