Results 1 to 7 of 7
    Sep 2009
    Bainsville Ontario
    MDS Fun and games.
    Does anyone have the male and femaile halves of the C100 connector that they would like to sell. It's the one tucked up under the cowel above and to the left of the trans dipstick tube. it has 12 smaller pins in 2 rows flanked by 4 larger pins, 2 on each side in a black plastic.
    I want to make a cheap Miller 8815 tool to check out my problematic MDS solenoids.
    Mar 2010
    Sedalia, Missouri
    This is on a 2008 Magnum with the 5.7 and AWD. My MDS system went intermentant Sometime it would work some times it wouldn't. Sometimes the check engine light would come on, then go off, then back on. I thought it was an open in one of the connectors, but I couldn't find anything. I could move the wiring behind the engine and the MDS would operate for a while.
    I took it to the dealer, and several hundred dollars it now works as it should. The parts they replaced, should anyone want to do this themselves are:
    4 ea 53032152AD solenoid
    8 ea 53032382AB seal
    1 ea 56045793AC wiring
    1 ea XXMS96574-19 PCV gasket
    1 ea 5277928 gasket
    1 ea 4591250 seal
    1 ea XX7305024-18 quick clip
    Good luck
    Sep 2009
    Bainsville Ontario
    In my case know which solenoid it is. #4 is showing an open circuit. I just want to make a tool to avoid making a mess of the harness connector.
    Mar 2010
    Sedalia, Missouri
    #4 was the error code on mine as well. If the circuit is open there "must" be an open connector or wire... All three circuits that go through C100 ohmed out the same. dealer said that when one goes bad, due to the difficulty in replacing the one, they replace all four coils, and the wiring harness. They did. No problem in the past four weeks.
    Sep 2009
    Bainsville Ontario
    Nobody??
    Jul 2018
    Williston Fla
    I was thinking of doing the same thing. Wouldn't it be easier to make one for the C-101, (Behind the left cyl hd) it only has 5 wires - 4 12v & 1 GND. I am currently making a load tester to check the harness. There is no voltage present until PCM turns it on somewhere above 15-20 mph with engine load setting just right. Ohm testing can be off if there is still a few strands of wire, but load the circuit and you will see a voltage drop. Solenoid #6 wiring does not past thru C-100, it goes direct to PCM.
    Mar 2010
    Atlanta
    One thing to keep in mind is the cost of repair of the MDS system vs shutting it down. As the 1st gen cars are not worth a lot, unless you repair yourself assuming you have free time, it might not be worth it given the rather low fuel savings MDS provides.
    I turned mine off as I was getting a vibration during operation and frankly was surprised to find in my driving cycle, I'm only averaging about 1-2mpg less.
    So averaging 12K miles a year currently the cost difference with MDS off will be about $150 more with fuel @ $2.30gal.
    If a dealer repair of the MDS system is $1K and I would bet its at least that or more...it would be close to another 7 yrs until I break even on the cost of the repair vs fuel savings lost.
