Results 1 to 9 of 9
    Jun 2018
    Ontario, Canada
    Newbie with transmission issue
    I recently bought my first Mopar, a 2005 Magnum with the 3.5L V6.
    I really like this car, but one day last week it was revving quite high (2200 rpm at 40mph). Today, it did it again, and when I stopped at a light, it wouldn't start moving when I accelerated. I shifted to park, then drive, and it was OK after that and the rpm was where it should have been.
    Any help would be greatly appreciated.
    Check for codes.
    Check the fluid level.
    Maybe drop the pan, change the filter and refill.
    Could it have been going into limp mode?
    Aug 2012
    New Jersey
    First and foremost, check the fluid level -- classic low fluid behavior.
    2010 AWD charger R/T -- Black -- daily driver
    2007 decommissioned police charger w/5.7 Hemi -- White -- 2011 project car (dropped valve seat) -- son's daily driver
    2006 decommissioned police charger w/5.7 Hemi -- Black -- 2013 project car (dropped valve seat) -- now the new 2018 project car
    2007 decommissioned police charger w/5.7 Hemi -- Black -- 2015 project car (dropped valve seat) -- Sold but still close by
    Jul 2016
    Ontario, Canada
    How do you "check the fluid level" without taking it to the dealer or using an aftermarket kit?
    2005 Magnum SXT 3.5L V6
    Aug 2012
    New Jersey
    Assume you have same setup as on the Hemi's -- no dipstick. Practically any shop should should have an appropriate dipstick and be willing to check for you for the price of adding some fluid. The process take all of a minute or two.
    Jun 2018
    Ontario, Canada
    Quote Originally Posted by 2005rtmag View Post
    Check for codes.
    I don't think it's in limp mode, because I was till able to drive at 100-110 km/hr, but the revs were around 3000-3500. I did notice when I got home that the engine light was on, so I will check the codes when I get home tonight. I just thought it strange that it was ok after shifting to park, then back into drive. I was also able to downshift manually, so it was in 5th gear.
    Jun 2018
    Ontario, Canada
    Quote Originally Posted by TheHandler View Post
    Thanks. I'll do that tonight as well as checking codes. I just bought the car, so I really don't know if the maintenance has been kept up. The engine light came on as well, so I didn't know whether it would be the engine or transmission. I assumed the transmission because after putting in park then drive it was alright.
    Apr 2015
    united kingdom
    you have bought first Mopar, where is the place you buy that stuff?
    Jun 2015
    Southern Connecticut
    Does it only happen when you first start it up, and then after the first drive, it's fine for the rest of the day?
    "Many true sports cars can be outrun by a powerful sedan." - Sir William Lyons, Chairman, British Leyland
