    Mar 2010
    Hawaii
    Grounding points
    Installing some morimoto hids into my 2008 chrysler 300c. Morimoto HD relay requires power and ground. Where are the oem ground points in the engine bay that i could use. Thanks for the help.
    Anyone else install some morimoto hids?
    Mar 2010
    Hawaii
    Ok so i actually think i found a nice write up in the knowledge base. So i guess next question is if anyone has installed some morimoto hid into there lx. Im currently doin a retrofit with some spyder lights.
    Nov 2007
    NorCal
    There are several good grounding points in the engine compartment, you'll find the wiring landing on them with ring terminals near the wiring harness(s). Be sure you get good metal to metal contact and weather proof your tap.
    X E Ryder
    Just Another Motorhead, Really.
    (midlife crisis activated)
