Page 3 of 13 FirstFirst 12345 ... LastLast
Results 31 to 45 of 186
  1. #31
    May 2017
    Jax Fl.
    It would be unusual for any RT not to have been manufactured without EVIC. Do you have steering wheel controls?
    No sir, no controls. Fully loaded, sunroof, power everything, leather. Just the cheap radio and no evic.
    Mopar CAI, Mopar Performance Torque Converter, MTCM, Tranzformer, 170 stat, Diablo 93 CAI tune + 5% fuel, RT Junkey’s ESP Mod, JBA shorties, cat delete thru Thrush Rattlers, UPR Catch Can, Eibach lowering springs, Mopar rear diffuser, Mopar front chin, Hurst T handle. 07 AWD Charger RT.
  2. #32
    May 2017
    Jax Fl.
    [QUOTE=RobsSXT;5091792]Yes. I did not need a steering column module (clockspring). And if you don’t have EVIC on your cause, the controls can still cycle through the limited menu non EVIC.
    Keep everything as close to your cars year as possible.
    Thanks, this sounds interesting i just dont want to have to start chasing down too many parts.
    Is there a way to determine if the proper clockspring is already there.?
    Or homelink?
    And why would the cluster need changed its already a 160 mph? is the evic a different design? I wouldn't think they would want to manufacture 4 different clusters 2 for v6 and 2 for 5.7.
    (evic and non-evic).
    Sorry for all the questions but you did make it work so I figure you have the answers.
    Thanks.
    And yes the key programing would be great.
  3. #33
    Aug 2009
    Quote Originally Posted by primalgeek View Post
    Thanks for sharing, I'm working on a CANBUS project to detect the steering wheel buttons for an external processor and this may actually make my life easier, I've emailed them to see if the app shows the PID's for events. I've also just bought the USB Scantool so I can play around with it.
    That sounds like something we could all use. Keep us posted k?
    05 Magnum AWD SXT Hemi Swap
    instagram.com/hemisxt
  4. #34
    Jan 2014
    Hampton Roads
    Thoroughly interested.
    Following for the future
    Sent from my Z981 using Tapatalk
    http://www.youtube.com/c/yachtlife
    '10
    Charger 3.5 (Engine)
    '10 Charger 5.7 R/T Police Package (Taken)
    01 Lincoln LS 3.9L V8 (Thrown Away)
    '05 Chrysler 5.7 300C "Hemmissy"
    Catless LongTubes, Mopar Exhaust, SRT MAX Cam, 20" 3-piece Adventus AVS-4, Eibach Sportline Springs, Dipped, Painted, Tinted, Decaled
    60ft:
    1/8:
    1/4:
    1Mil:
    Top Speed:
  5. #35
    Calgary, Alberta
    Quote Originally Posted by Root66 View Post
    Sorry, I see no mention of editing mileage. Can it be done?
    Mileage changes are a Dealer function (subject to legalities).
  6. #36
    Aug 2009
    EVIC now possible WITHOUT the dealership. I just did it.
    Quote Originally Posted by Slickawd View Post
    Or homelink?
    Thanks.
    Clockspring is fine. I've read where Challenger guys trying to do this ran into Steering Control Module (SCM) differences. As for me, and my 05, I didn't need to change anything.
    Homelink is the garage door opener above your rear view mirror. I got mine from my local auto wreckers for $25. Make sure you have the harness. The harness goes down the passenger A pillar to a connection in your wiring harness. Plug and play. This also has the compass that you will see in your display.
    • 140 speedo is the SXT. No EVIC option that I'm aware of.
    • 160 is the RT. It has the full EVIC that I enabled. Some RT's didn't come with EVIC, just with the basic display under the speedometer.
    • 180 is the SRT gauges, they all have EVIC.
    Then there the ones for the Canadian/ overseas market in metric. So now thats 8 different clusters.
  7. #37
    Apr 2010
    Chicago
    Will this also read Airbag codes?
    How about calibrate sunroof or HVAC?
    Sent from my iPhone using Tapatalk Pro
  8. #38
    Aug 2009
    Quote Originally Posted by 94cruiser View Post
    Yeah it does airbag codes thank goodness. I have a persistent code. HVAC- you can troubleshoot the entire thing because you can trigger every actuator individually in the system. No sunroof functions.
    In terms of a stand alone code reader, it’s the best I’ve ever bought.
  9. #39
    Feb 2016
    I read through the website and this thread and saw mentions of being able cycle individual actuators. Does anyone know if this software will let you cycle the ABS module for bleeding the brakes?
  10. #40
    Apr 2010
    Chicago
    Would I be better off getting a USB based interface or BT?
    My Windows laptop is somewhat older Dell Latitude E4310 i5 with SSD drive running Windows 10.
    I know it does not have BT 4.0
    Lastly there is no trial mode of any kind, right? Limited features or 1x use or time limited...
  11. #41
    Aug 2009
    I have BT ones but I just wanted a good reliable connection. Probably works fine on your PC.
  12. #42
    Feb 2016
    Yea I just checked and saw all this. Could this allow a makeshift line lock?
    EDIT- the site is saying I exceeded my quota.
    Thanks for the reply. Can't tell what is in that pic though.
  13. #43
    Aug 2009
    Quote Originally Posted by ramblinmike View Post
    I was having problems uploading last night. And still am.
  14. #44
    MPLS/STP - MN
    Wonder if that connection device would work with the CDA software...
    Click this link to see Photobucket images again!
    Follow White Ops R/T on Instagram, Twitter, and Facebook.
  15. #45
    Feb 2009
    Knoxville, TN
    RobsSXT, are you able to check and see if you can see the PID's in the software when you hit the steering wheel buttons? I've not heard back from them yet. I'm looking for the actual codes so I can have an arduino sniffing the CANBUS looking for them, but I have to have the actual PID's. I can get them with the Ardiuno but its a tedious process to filter through all the other traffic.
    thanks
    Lovin me some BBW - Big Beautiful Wagon
    06 Inferno Red SRT8-
    Gofast: Frankentake, MTCM, Tranzformer, Diablo Trinity, Billy Boat Cat back
    Gocontrol: Eibach front/rear sways, Morpar strut tower
    Goloud: Joying Android 10.1" Head Unit, Helix MK2 Pro with Director sound processor, Raspberry Pi running Moode Audio, Hybrid l4 dash/Sundown SAX 100.4, Hybrid Legatia 8 SE in kick panels/ Hybrid l1v2 tweeters/Sundown SAX 100.4, 2 Sundown Zv5 15's/Sundown SCV 4000D's
    >>Click Here to see my Audio Build log <<
