Going to need to find an "always on" power connection for a dash cam. Anything besides the rear fuse box that I could use? Would like to locate something in the dash for a shorter wire... Hoping someone could give a quick tip before I start poking around with a multi meter.
The front power plug can be set to switched or constant via fuse 18 in the rear fuse box otherwise large plug in back of radio has 2 wires that are always on. Two wires, same colour, top and bottom at one end of that plug.
You mean the elbow console power outlet? Good idea, thank you! I have installed a myGig unit with a lock pick years ago... not the original stock radio. Will need to look at what wires it has "always on".
The other thought was dome lights, they are always on, aren't they?
Switch fuse 18 in the rear box to the other position (I forget if it's upper or lower but it will be opposite to what it is now)- it will become constant
Related Threads
LX Forums Forum
5.2M posts
122.9K members
Since 2004
