Page 3 of 4 FirstFirst 1234 LastLast
Results 31 to 45 of 54
  1. #31
    MPLS/STP - MN
    ^^Thanks. Both were ripped out. The wife hit something a few nights back, destroyed the front pan, and dropped the rear pan during out last (and final) snow storm.
    Click this link to see Photobucket images again!
    Follow White Ops R/T on Instagram, Twitter, and Facebook.
  2. #32
    Nov 2012
    Uxbridge, Ontario
    Yeah, if anyone happens to know what is needed in terms of hardware, or where I could find a listing that would be fantastic!
    When I got my car, the rear pan was held on with a couple zip ties, and we just took the front pan off the other day because it was only being held up by 2 screws so I have nothing but those 2 screws to reference new hardware :(
    Thanks!
    2005 Silver Magnum RT
  3. #33
    Apr 2013
    At 197 MPH the Challenge chin spoiler rips off ( not mine - some guy doing the Texas Mile)....................*~:',~
  4. #34
    Feb 2011
    Akron, OH
    Quote Originally Posted by MissMaggie View Post
    Thanks!
    If you have a reasonable dealer parts department (like I do) go ahead and hit them up. I replaced all the nuts and bolts when I first got my 300 for like $10. The bolts have already been mentioned and I would figure they can also be had at a decent hardware store. The snap in nuts are harder to locate. So, when I asked the parts department how much one was I was so happy I told them to get me all the hardware....
    Jeff
    2010 Jeep Liberty Limited; Red / Beige Leather
    1985 Dodge 600ES Turbo Convertible (only 45k original miles)
    2006 Mercedes R350 (Wifey's kiddie bus)
    Gone: 2007 Chrysler 300C; Cool Vanilla (Diablosport Predator, B/T Catch Can, AEM Brute Force Intake)
    "Just because you read the manual, doesn't mean you can drive the car"
    www.terminalsandconnectors.com
  5. #35
    Jan 2009
    Lawrence, Kansas
    Does anyone know what the part number for the front belly pan is on Rock Auto?
    I saw someone posted the link to the rear, but I've been unable to find the front one on there. I could be looking in the wrong category, but I've gone through all of the exterior panels categories and am still unable to find it.
    Otherwise, does someone have a suggestion as to where I should order it? I called the dealership and they wanted outrageous amounts. The inner fender liners that are $13 a piece on RA are like $80 at a dealership, so I figure the belly pan is probably the same way.
    Making sexy look easy since 1983.
    Stay Subtle
    Quote Originally Posted by CVP33 View Post
    Get a procharger. I only chirp 4th now. The other gears are just a blazing, screaming, tire shredding, smoke filled show of power. But definitely no chirping.
  6. #36
    May 2013
    THE IE (91762)
    Quote Originally Posted by Sevenernine View Post
    part number is CH1228105 SPLASH GUARD $28.79 PLUS SHIPPING.... click all of these, rockauto.com.....dodge....year....car type....engine.....engine cover.....its a splash guard.... or you can just type in the part number i provided... just got mine on friday last week. pm me if you can't find it....
    <a href=http://s1063.photobucket.com/user/hostage42/media/-851230676.jpg.html target=_blank rel=nofollow><img src=http://i1063.photobucket.com/albums/t516/hostage42/-851230676.jpg border=0 alt= /></a>
  7. #37
    Jan 2009
    Lawrence, Kansas
    Quote Originally Posted by hostage42 View Post
    Ah, duh! Of course it's an engine cover, it just covers the bottom! Doh!
  8. #38
    Apr 2013
    [QUOTE but after closer examination I saw that the air coming in through that new opening built up enough pressure to push the plastic inner fenders against the front tires... the smoke I saw was the inner fenders about to catch on fire! I plan on replacing the piece soon,
    It is both for "aero" and to scavenge heat from the radiator and engine to either side of the car, behind front wheel wells.
  9. #39
    Feb 2007
    L.A., Ca.
    Not unless you're super sonic!
    the front (smaller pan) ties into the fender wells and keeps them in place. The rear pan keeps out dust and dirt. and has to be removed to change the oil.
    IIRC, Meister removed only the rear cover to obtain better air flow through the engine bay.
    As you know, heat rises. I removed the top rear cowl cover around the wipers, and a ton of heat exits there. I don't drive in the rain, so no problem there.
    IIRC fireman2118 has had his upper cowl cover louvered to reduce heat - pretty cool!
    I don't drive my car enough in dirty conditions to need the rear panel.
    However, I've noticed more dirt in the engine bay. As I add more bling, I may re-install it.
    FI IV.5, Solo cat backs, 180 thermo, Catch Can, DS tuner, 383 Stroker/SRT heads,headers and mids,, Tranny cooler with fan control, built tranny/flex plate/4K conv,09 Chally rear with Quaife posi. Pedders Track II, coil overs, Hodgkiss sways, BWoody links, 20" Jacks N Five with Nitto Invo's, Custom brakes by TCE. Bling by BT.
    Just a grocery getter!
  10. #40
    Apr 2013
    Try kneeling behind the front wheel well (either side) when the engine is hot and running (not your car).
  11. #41
    California
    Quote Originally Posted by Hal'sMag View Post
    The rear pan (along with the front) is for aerodynamics (efficiency) and I'd say there is an excellent chance it *improves* air flow through the engine bay.
    The idea is to draw air *through* the engine bay. Through the radiator and through the engine bay.
    If you're seeing more dirt in the engine bay without the pan it's evidence that you're probably reducing air flow through there. Implication is that there is air coming up from where the pan was into the engine bay. So you have air coming in through the radiator and air coming up from where the pan was. End result is you are probably just increasing the pressure a little bit in the bay with less flow through there. Probably creating more turbulence underneath the car too. Lol, getting slower times without the pan?
    I've got more even and simultaneous combustion...
    2006 Magnum SRT8 - Brilliant Black
  12. #42
    Nov 2006
    Medford, Long Island
    I do not have the front or rear pan on. What are the clips and/or bolts needed to put these parts back together?
    CURRENT MODS: AFE II Intake-PWR Heads and Cam-SLP Long Tubes-SLP UD Pulley-Borla 125s-Eagle Intake-NGK V Power Plugs-Moder Muscle Throttle Body-Mopower Chin Spoiler -BT Oil Catch Can-Innovate Wideband-Eibach Dampers-Hotchkis Sway Bars and Lowering Springs-SRT 8 Gears, Mopar TCM-Edge Racing Converter-TransZformer Shift Kit-Lows/Fogs HIDs
  13. #43
    Dec 2004
    maine usa
    My pan came off at around 160 mph. I wasn't driving, I was standing beside the road about 1 mile from where my friend started my Magnum, about 100 feet past me, I heard a hell of an explosion and saw something flying thru the air. It blew off the pan and collapsed the fender liners on to my front tires. My friend who used to drag race a 502 BBChevy Monte Carlo, was a mite surprised. Now I have laces the fender skirts on to the fenders with heavy black tie wraps. Never replaced the pan, had her to 160 a few times, nary a problem, hood didn't bulge upwards like I had expected.
    FRI Sidewinder cam, Dynatec LT Headers , BorlaCatback , 93 octane dyno tune, 333rwhp/350 ft lbs, Police Pack Oil Cooler, SRT 8 Struts and Nivo's ,Hotchkis sway bars,B Woody end links, , 275/40/20 Ventus ST's , 2017 CC Big Horn Ram 4X4 EcoDiesel. Never Trust a Fart
  14. #44
    Nov 2006
  15. #45
    California
    Quote Originally Posted by formerice View Post
    Get a GoPro. Might be surprised at how your front facia is deforming at speed. Maybe tie wraping it to the liners helps but the front belly pan provides support for the facia.
