Page 487 of 487 FirstFirst ... 387437477485486487
Results 7,291 to 7,299 of 7299
  1. #7291
    May 2011
    Toronto, Ontario
    Quote Originally Posted by XFR SRT8 View Post
    Are the 300c skirts different? I always assumed they were the same!
    The 300 ones have less of a "ledge" on them.
    2006 300 SRT8 / 2012 300 SRT8
  2. #7292
    Mar 2014
    San Diego, CA
    The 300 rocker panels have a slight ledge to them, and then are a smooth radius to underneath the car. The Magnum has a concave section before it flattens out to wrap underneath the car.
    300 Rockers:
    This Magnum w/300 swap still has the Magnum rocker panels on it
    Mine with the 300 rockers on it
    Even the 300 Tourings sold in Europe and Australia had the Magnum rockers from the factory.
    - Brian T.
    "Pam the Demon Wagon" 2006 Magnum SRT
    8 #That70sSRT8
    | web: Michael Brian Studios | instagram: @MichaelBrianStudios |
    Likes XFR SRT8 liked this post
  3. #7293
    Dec 2014
    Delaware
    Quote Originally Posted by MikuhlBrian View Post
    Got my bumper back from paint and installed. For the most part my 300 front end swap is complete.
    Great job! Looks amazing!
    Did you ever wire up the ambient lighting on the door panels?
    2006 300 SRT8
    Accuair Equipped
    Avant Garde F431 (Electron Blue)
    IG: @bagged_srt
  4. #7294
    Mar 2014
    San Diego, CA
    Quote Originally Posted by 5280SRT8 View Post
    Thanks. I "sorta" got the amibient lighting working on the front door panels. I'll have to go back in and remember what wires I tapped into. The driver's side is dimmer than on the passenger side, and they are on all the time when the car is running. I have yet to figure out what wires to tap into for the rear doors, of the wiring that is already in the door. Once I figure it all out, I'll do a quick write up for the site.
  5. #7295
    Dec 2007
    Riverside, California
    For the rear doors, you can tap into pins 6 and 4 of the window switch. That will give you switched power, to the ambient lights. If you press the window lockout button, on the driver master switch, both rear door window switch lights and ambient light will extinguish.
    If you tap into the front passenger 6 pin connector, on the window switch... pin 3 is ground and pin 1 is power. This will also give you switched power, via the driver door master switch.
    Bob
    http://www.luxte.ch
    Lux Technologies
    Likes body80, BryGuy liked this post
  6. #7296
    Mar 2014
    San Diego, CA
    Quote Originally Posted by diboblo View Post
    For the rear doors, you can tap into pins 6 and 4 of the window switch. That will give you switched power, to the ambient lights. If you press the window lockout button, on the driver master switch, both rear door window switc lights and ambient light will extinguish.
    Bob
    Thank you! Thank you! Thank you! Thank you! Thank you! Thank you! Thank you! Thank you! Thank you! Thank you! Thank you! Thank you! Thank you! Thank you! Thank you! Thank you! Thank you! Thank you! Thank you! Thank you! Thank you! Thank you!
  7. #7297
    Dec 2007
    Any time brother.
    It's what I do...
    Bob
  8. #7298
    Dec 2014
    Delaware
    Bob
    Thanks Bob!!
  9. #7299
    Jan 2020
    Ever since I got my 300 I've been irritated by this mystery object on my kick panel that was really hacked in there with Ttaps and such. Worst install I've ever seen.
    Turns out to be the "security" system that dealers put in to up sell even though the vehicle has an OE system. Reason seems to be that this is also a GPS tracker and a remote kill system in case you miss payments.
    Don't need. Would not recommend.
    For now I left the Ttaps alone until they completely destroy my interior wiring harness. Only solder for now was to repair the ignition wire.
