Results 1 to 15 of 25
    Hideous Split Loom!!
    Looking for options to replace or hide the hideous split loom on our cars. Ruins and cheapens the look of the engine bay. Thanks in advance!
    K-1 Technologies 426 Stroker kit, Custom Wiseco inverted dome pistons, port & polished heads and intake, custom grind Comp 426 cam, Polished T-Trim Vortech supercharger, Kooks Longtube headers with flowmaster exhaust, CPR Fuel rails, Walbro 255 fuel pump, MSD Ignition, ARP mains and studs, ATI Balancer, DSS 1000 HP Shafts, LSD, custom Vaca Performance Tune, KW coilovers, Hotkich sway bars, Asanti 3-piece AF-403, polished and anodized engine bay, RK Sport Heritage wing, Alpine and JL audio system, AAC Oracle Demon Eye headlights, tails, and HID Conversion
    www.projectsrt.com
    Aurora, IL
    the braided nylon stuff looks a litttle better but it'll be a bitch to get over the harness b/c of all the branches. i've seen people do braided over them, but there's no attractive way to finish off the ends that way.
    Posted via LXFMobile
    Dec 2005
    Arizona
    I relocated some of my wire loom and added the braided nylon stuff (^^^). I too wanted to have a more finished look, so I used black and gray strips of double sided Velcro to wrap each end. The cheap gray stuff was not holding as well as I would of liked so added some small tie wraps, with the connections hidden towards the back. I will probably try to find some other Velcro with a bit better quality.
    When you do things right, people won't be sure you've done anything at all.
    My friends call me JONN (usually).
    Jan 2007
    Brunswick, Oh
    Quote Originally Posted by MAGFX View Post
    Real clean! I like it. What's the install trick?
    2011 Dodge RAM Outdoorsman, Emerald Green, Navigation, Sirius, DVD player. So many mods to choose, so little $$!
    Formerly 2007 Dodge Charger R/T.
    Dec 2007
    Long Island, NY
    why not just use some shrink wrap on the ends? you can get it in just about any color.
    Mar 2008
    Lusby, MD USA
    Quote Originally Posted by Frozen_ View Post
    It's hard to get the shrink wrap around the connectors.. the PET or Nylon sleeving expands up to three times it's collapsed diameter allowing it to fit around the connectors. I think?
    eGo
    Who Farted? BEANIE!!!
    !Welcome to the United States of the Offended!
    Mods : Inertia Performance Heads, Inertia v1.1 Cams, MM Ported 71mm Throttle Body, JBA Shorty Headers, Airhammer HO, Predator w/Custom Tune from Stu, RT Brakes, Eibach Pro Kit, RT Exhaust, 20" Vipers
    Jun 2005
    Fountain Valley, CA
    That's really nice! You must be using split nylon loom, right? I can't imagine you disassembled each connector to use the continuous loom. Even as much as they expand I doubt it would fit over those connectors.
    How do I.... EVERYTHING!
    SoCalLX - Where Southern California Car Culture Meets Modern Mopar Muscle
    Dec 2005
    Arizona
    No trick really, just patience and TLC.
    I used several sizes of braided covering, Velcro, tie wraps, scissors, and a lighter to melt the frayed ends. I pulled most of the factory electrical type tape and the split looms in order to reposition and do a better wrap job.
    Once all of the covering was on, I put the strips of double sided Velcro at each junction and end. I did it in stages since it did take a bit of time, but I think that it result was worth it. Cheers...
    Quote Originally Posted by mnunes View Post
    Yeppers, I used a split loom. I did try a split loom with Velcro on one edge, but it did not work so well with the constantly changing diameter of the loom, plus it look a bit bulky.
    I did not want to use heat shrink tubing due to the relatively large plug ends, plus trying to get it over the loom at the transition connections would be a "bear".
    Dec 2007
    Long Island, NY
    they make high ratio heat shrink that might work
    Could likely get away with some 6:1..
    http://cableorganizer.com/heat-shrin...rink-tube.html
    I like this stuff as it has an adhesive inside of it.. it helps keep the ends of the nylon mesh from slipping out..
    but even 6:1 may not be enough to get over some of the connectors...
    Dec 2005
    Arizona
    I just might have to try some of that, at least for the ends. Thanks!
    Feb 2008
    Langley B.C. ....2018 Challenger SRT
    That is usually what it takes...clean job Jonn...attention to detail is very obvious...looks sweet...
    Horsepower, never enough.
    Aug 2007
    Olympia, WA
    For a second there, I thought you had put a breather filter on your fuel rail!
    MAN that's clean! Best i have seen. Once i get my new motor back, i can see this being one of the 1st projects! Thanks for your advice and photos. Gotta love forums!!!
    Jul 2008
    Green Bay, WI
    there is a company that makes the split "tech flex" looking loom like he has in the pictures.... I think painless wiring sells it.
