fuse location/amp rating/circuit protected *
316K views 42 replies 24 participants last post by  nyrican
#1 · (Edited)
these are for '06 magnum but should be the same for all LXs '07 & older.
Power Distribution Centers
Front Power Distribution Center Fuses
A power distribution center is located in the engine compartment. This center contains fuses and relays.
CAUTION:
  • When installing the Power Distribution Center cover, it is important to ensure the cover is properly positioned and fully latched. Failure to do so may allow water to get into the Power Distribution Center, and possibly result in a electrical system failure.
  • When replacing a blown fuse, it is important to use only a fuse having the correct amperage rating. The use of a fuse with a rating other than indicated may result in a dangerous electrical system overload. If a properly rated fuse continues to blow, it indicates a problem in the circuit that must be corrected.
Cavity/ Fuse /Circuits
1/ 20 Amp Yellow/ Left High Beam Headlight
2/ 20 Amp Yellow/ Right High Beam Headlight
3/ 15 Amp Dk. Blue/ Adjustable Pedal
4/ 20 Amp Yellow/ Horn
5/ 25 Amp Clear/ Headlamp Washer - If Equipped
6/ 15 Amp Dk. Blue/ Front Control Module (FCM)
7/ 20 Amp Yellow/ Fog Lamp
8/ 15 Amp Dk. Blue/ Park Lamp
9/ 15 Amp Dk. Blue/ Non ABS Brakes
10/ 5 Amp Orange/ Starter
11/ 20 Amp Yellow/ Auto Shutdown/Powertrain Control Module (PCM)
12/ - -
13/ - -
14/ 25 Amp Clear/ Powertrain Control Module
15/ 20 Amp Yellow/ Injectors, Ignition Coils
16/ 15 Amp Dk. Blue/ Powertrain Control Module
17/ 30 Amp Pink/ Antilock Brake System (ABS) Valves
18/ 30 Amp Pink/ Windshield Wiper/Washer
19/ 50 Amp Red/ Radiator Fan
20/ 20 Amp Lt. Blue/ Starter
21/ 50 Amp Red/ ABS Pump Motor
22/ 40 Amp Green/ Radiator Fan High/Low
23/ 50 Amp Red/ High Intensity Lighting
24/ - -
25/ 30 Amp Pink/ Lighting Left High Beam/Right Low Beam
26/ 20 Amp Lt. Blue/ Transmission
27/ 30 Amp Pink/ Lighting Left Low Beam/Right High Beam
Rear Power Distribution Center Fuses
There is also a power distribution center located in the trunk under the spare tire access panel. This center contains fuses and relays.
CAUTION:
1/ 60 Amp Clear/ Ignition Off Draw
2/ 40 Amp Green/ Battery
3/ - -
4/ 40 Amp Green/ Battery
5/ 30 Amp Pink/ Heated Seat/Steering Column
6/ 20 Amp Yellow/ Fuel Pump
7/ - -
8/ 15 Amp/ Dk. Blue Ignition Start/Run - Start
9/ 20 Amp Yellow/ Console Power Outlet
10/ 10 Amp Red/ Rear Fog Lamp - If Equipped
11/ 25 Amp C/BRKR/ Memory Module/Door Locks
12/ 25 Amp C/BRKR/ Passenger Power Seat
13/ 30 Amp C/BRKR/ Door Module Run/Acc/Delay
14/ 10 Amp Red/ Sentry Key/Remote Keyless Entry/Cluster
15/ 20 Amp Yellow/ Brake Light (5.7L)
16/ 20 Amp/ Yellow/ Power Outlet Trunk - if equipped
17/ - -
18/ 20 Amp/ Yellow Selectable Power Outlet
19/ 10 Amp/ Red Stop Lamp
20/ 20 Amp Yellow Rear Wiper - If Equipped
21/ - -
22/ - -
23/ - -
24/ - -
25/ - -
26/ - -
27/ 10 Amp Red/ Airbag/Occupant Classification Module
28/ 10 Amp Red/ Curtain Airbag - if equipped
29/ 5 Amp Orange/ Sentry Key/Remote Keyless Entry/Powertrain Control Module Ignition Feed
30/ 10 Amp Red/ Steering Column Module/Power Mirrors - if equipped
31/ - -
32/ - -
33/ - -
34/ - -
35/ 5 Amp Orange/ Power Antenna/Garage Door Opener/Ignition Delay
36/ 20 Amp Yellow/ Radio/Navigation
37/ 15 Amp Dk. Blue/ Transmission
38/ 5 Amp Orange/ Analog Clock/Garage Door Opener / trunk light (charger)
39/ 10 Amp Red/ Heated Mirror
40/ 5 Amp Orange/ Power Mirror
41/ 10 Amp Red/ Climate Control Module/Headlamp Leveling - if equipped/Rear Park Assist - if equipped/Tire Pressure Monitoring - if equipped
42/ 30 Amp Pink/ Automatic Temperature Control (ATC) Blower Motor
43/ 30 Amp Pink/ Rear Defroster
44/ 20 Amp Lt. Blue/ Audio Amplifier / sunroof
thanks to Tbird100636 for posting this '08 front fuse box (TIPM) diagram and fuse & relay chart:
Here's a diagram of the TIPM (The sucessor to the IPM, more advanced functonality) Because of the stupid Adobe SVG viewer they use 2007 up, I had to copy it piece by piece. Here it is...
Fuses:
1.-15A-TIPM internal electronics-Washer Motor
2.-25A-ASD Relay coil and PCM
3.-25A-Run/Start Relay
4.-25A-S143-To PCM (Gas) ECM (Diesel)
5.-15A-ECM (Diesel)
6.-25A-ASD relay output-to S107-to various powertrain components(Gas) S156 to various powertrain components (Diesel)
7.-25A-Underhood Lamp (Police), Headlamp Washer Relay (Via S130)
8.-25A-Starter Relay Contacts
9.- Starter Relay
10.-30A-Wiper On/Off Relay, Wiper High/Low Relay Coil
11.-30A-ABS Module-Control Valves
12.-40A-Radiator Fan Control Relay
13.-50A-ABS Module-Pump Motor
14.-Not used
15.-50A-Radiator Fan High Low Control Relay Coil, Radiator High Fan Relay
'08 Challenger
FUSES/INTEGRATED POWER MODULE (IPM) - SRT8
Integrated Power Module (IPM)
The Integrated Power Module (IPM) is located in the engine compartment. This module contains fuses and relays.
CAUTION:
  • When installing the integrated power module cover, it is important to ensure the cover is properly positioned and fully latched. Failure to do so may allow water to get into the integrated power module and possibly result in an electrical system failure.
Cavity | Cartridge Fuse | Mini-Fuse | Description
1 | - | 15 Amp Blue | Washer Motor
2 | - | 25 Amp Neutral | Powertrain Control Module (PCM)
3 | - | 25 Amp Neutral | Ignition Run/Start
4 | - | 25 Amp Neutral | Alternator
5 | - | - | -
6 | - | 25 Amp Neutral | Ignition Coils/Injectors
7 | - | - | -
8 | - | 25 Amp Neutral | Starter
9 | - | - | -
10 | 30 Amp Pink | - | Windshield Wiper
11 | 30 Amp Pink | - | Anti-lock Brake System (ABS) Valves
12 | 40 Amp Green | - | Radiator Fan
13 | 50 Amp Red | - | Anti-lock Brake System (ABS) Pump Motor
14 | - | - | -
15 | 50 Amp Red | - | Radiator Fan
16 | - | - | -
17 | - | - | -
18 | - | - | -
19 | - | - | -
20 | - | - | -
21 | - | - | -
22 | - | - | -
'08 Challenger
CAUTION:
  • When installing the Power Distribution Center cover, it is important to ensure the cover is properly positioned and fully latched. Failure to do so may allow water to get into the Power Distribution Center, and possibly result in an electrical system failure.
Rear Power Distribution Center Fuses - SRT8
1 | 60 Amp Yellow | - | Ignition Off Draw (IOD)
2 | 40 Amp Green | - | Integrated Power Module (IPM)
3 | - | - | -
4 | 40 Amp Green | - | Integrated Power Module (IPM)
5 | 30 Amp Pink | - | Heated Seats - if equipped
6 | - | 20 Amp Yellow | Fuel Pump
7 | - | 20 Amp Yellow | Sub Amp - if equipped
8 | - | 15 Amp Blue | Diagnostic Link Connector (DLC)/Wireless Control Module (WCM)/Wireless Ignition Node (WIN)
9 | - | 20 Amp Yellow | Power Outlet
10 | - | - | -
11* | - | - | -
12* | - | - | -
13* | - | - | -
14 | - | 10 Amp Red | AC Heater Control/Cluster/Security Module - if equipped
15 | - | 20 Amp Yellow | -
16 | - | 20 Amp Yellow | -
17 | - | 20 Amp Yellow | Cluster
18 | - | 20 Amp Yellow | Selectable Power Outlet
19 | - | 10 Amp Red | Stop Lights
20 | - | - | -
21 | - | - | -
22 | - | - | -
23 | - | - | -
24 | - | - | -
25 | - | - | -
26 | - | - | -
27 | - | 10 Amp Red | Occupant Restraint Controller (ORC)
28 | - | 10 Amp Red | Ignition Run
29 | - | 5 Amp Orange | Cluster/Electronic Stability Program (ESP)/Powertrain Control Module (PCM)/STOP LIGHT Switch
30 | - | 10 Amp Red | Door Modules/Power Mirrors/Steering Control Module (SCM)
31 | - | - | -
32 | - | - | -
33 | - | - | -
34 | - | - | -
35 | - | 5 Amp Orange | Antenna Module - if equipped/Power Mirrors/Rain Sensor - if equipped
36 | - | 20 Amp Yellow | Hands-Free Phone - if equipped/Video Monitor - if equipped/Radio
37 | - | 15 Amp Blue | Transmission
38 | - | 10 Amp Red | Cargo Light/Vehicle Information Module - if equipped
39 | - | 10 Amp Red | Heated Mirrors - if equipped
40 | - | 5 Amp Orange | Auto Inside Rearview Mirror/Heated Seats - if equipped/Switch Bank
41 | - | 10 Amp Red | AC Heater Control/Headlights/Park Assist - if equipped/Tire Pressure Monitoring - if equipped/Occupant Restraint Controller (ORC)
42 | 30 Amp Pink | - | Front Blower Motor
43 | 30 Amp Pink | - | Rear Window Defroster
44 | 20 Amp Blue | - | Amplifier - if equipped/Sunroof - if equipped
*Cavities 11, 12, and 13 contain self-resetting fuses (circuit breakers) that are only serviceable by an authorized dealer. The Cluster (without power memory seat), the Driver Seat Switch (with power memory seat), and the Memory Module (if equipped) are fused by the 25 amp circuit breaker in Cavity 11. The Passenger Seat Switch is fused by the 25 amp circuit breaker in Cavity 12. The Door Modules (except base), the Driver Door Lock Switch (base), the Driver Express Power Window Switch (if equipped), and the Passenger Door Lock Switch (base) are fused by the 25 amp circuit breaker in Cavity 13. If you experience temporary or permanent loss of these systems, see your authorized dealer for service.
2011
#35 ·
2010 Challenger SRT8 HVAC inop after dead batter
Posting since Google brought me to this thread regarding my search for a diagram of the trunk fuse box of my 2010 Challenger SRT8
My battery went completely dead a couple days ago while doing a rear end swap (have car in neutral for 2 days = dead battery). Jumped it off and thought all was well till I noticed the Air Conditioning would blow air but not cool. Lil indicator light in the knob would not light up. Found that I needed to simply pull and replugin the #14 fuse. Some diagrams show a fuse #41 but on my car that was empty.
Circuit component Hardware programmer Audio equipment Passive circuit component Electronic component
#38 ·
I have a 06 Chrysler 300 The front power distribution center is not showing power at my powertrain control module #14 & # 15 and injectors ignition coil #13
fuses in cavities 14 & 15 are powered by the ASD relay and will only have power when the engine is running and for 2 seconds after key on. cavity 13 is not populated.
#39 ·
My 2008 MSRT8 has stock HID low beams that are not coming on with the switch or even the alarm disarm function (high beams work). So I am reading there is no fuse, but cannot locate the "high side driver" slot or a relay on any diagram for the low beam. any ideas on how I should proceed? Thanks! Bill
Reactions: johnnottom
#40 ·
Anyone know which relay in the fuse box controls the front wipers on a 2006 300C?
