Useful Mercedes Part Numbers
70K views 74 replies 37 participants last post by  Berserker
#1 · (Edited)
This list provides Mercedes part numbers for items useful to LX owners.
Ok, first item is the transmission dipstick
This allows checking the fluid level without having to use the starscan for tranny temps.
140 589 15 21 00
Trans Pan w/drain plug
140 270 08 12
Transmission Pan Gasket
Normal maintenance part
140 271 00 80
Transmission Filter
140 277 00 95
Transmission Electrical plug Adapter with O-rings.
You need this if you have a leak at the plug on the transmission.
203 540 02 53
Transmission Electrical plug Adapter O-rings.
These are replacement o-rings for the above plug.
026 997 40 48 28
026 997 41 48 28
Blue Top Transmission Solenoids
These will increase line pressure and therefore shift firmness in the 5 speed NAG1 Tranny.
240 270 00 89
Rear Diff Cooler and required Diff Cover for 215mm rear
Keep those rears cooled off.
Cooler: 171 351 0108
Cover: 204 351 05 08
Thanks to Jim McVeigh
Parking Brake Pedal Cover (Matches Mopar Pedal Covers)
203 430 00 84
!!!May need a bit of trimming to the rubber back in Auto cars!!!
Thanks to Speedy at Challengertalk.com
More to come.
#70 ·
I know i am kinda pulling this thread from the grave, but does anyone know if the rear diff cooler would work on a 06 300c AWD?
#71 · (Edited)
Clarifying 215mm differential cooler part numbers...
Rectifier (heat sink cooler)...~$90 A 171 351 01 08
Cover (finned diff cover)......~$210 A 204 351 06 08 (compared to the A 204 351 05 08 listed on several threads)
^^UPDATE: Though the -06 08 cover is finned unlike the -05 08 cover, the passenger side mount is on a tab/ear instead of between the two bolts on the right side of the pumpkin, so the cover is still incorrect!^^
Bolts (you need two)...........~$5 N000000 001536
(Sorry, no pics of parts because LXF doesn't do simple, direct uploads.)
I don't want anyone else to waste $200 on this thinking it'll work - it won't. Just fab up the 1"x6" aluminum spacer as others have done.
#72 · (Edited)
Can you email me some pictures of this diff cooler as I am transplanting a newer 215mm SRT rear cradle with diff and may be
interested in adding this cooler. I would assume there are some benefits to this as well?
Adding CORRECT 215mm differential cooler part numbers that come from the E63, SL63, CLS63 and SL65...
Rectifier (heat sink cooler) ~$90 A 204 351 06 08 !!! That is 06, zero six, and NOT 05 !!!
Cover (finned diff cover) ~$210 A 171 351 01 08
Bolts (you need two) ~$5 N000000 001536
#73 · (Edited)
PM me an email.
According to fellas on the Benz forums, there was a Mercedes-Benz AMG press release (non-US) that claimed a 15°C cooling ability for this passive heat sink.
This "rectifier" meant to prevent cooking the pumpkin's oil during sustained, high-speed driving. Magazine reviews of tracking the US AMG models (without the diff cooler) apparently experienced some oil sputtering out of the vent after lapping sessions, so a case for the cooler is evident.
#74 ·
Thankyou I will pm you my email and I'd be interested in that part you have
as well.
Just send me an email. The cover usually comes from Germany and may be backordered. (I wound up with two covers so I have one available to sell.)
#75 ·
0009976532 for replacement drain plug for transmission pan, appears to be stronger than the old one.
