This list provides Mercedes part numbers for items useful to LX owners.
Ok, first item is the transmission dipstick
This allows checking the fluid level without having to use the starscan for tranny temps.
140 589 15 21 00
Trans Pan w/drain plug
140 270 08 12
Transmission Pan Gasket
Normal maintenance part
140 271 00 80
Transmission Filter
140 277 00 95
Transmission Electrical plug Adapter with O-rings.
You need this if you have a leak at the plug on the transmission.
203 540 02 53
Transmission Electrical plug Adapter O-rings.
These are replacement o-rings for the above plug.
026 997 40 48 28
026 997 41 48 28
Blue Top Transmission Solenoids
These will increase line pressure and therefore shift firmness in the 5 speed NAG1 Tranny.
240 270 00 89
Rear Diff Cooler and required Diff Cover for 215mm rear
Keep those rears cooled off.
Cooler: 171 351 0108
Cover: 204 351 05 08
Thanks to Jim McVeigh
Parking Brake Pedal Cover (Matches Mopar Pedal Covers)
203 430 00 84
!!!May need a bit of trimming to the rubber back in Auto cars!!!
Thanks to Speedy at Challengertalk.com
More to come.
140 589 15 21 00
140 270 08 12
140 271 00 80
Transmission Filter
140 277 00 95
203 540 02 53
026 997 40 48 28
026 997 41 48 28
240 270 00 89
203 430 00 84
More to come.
