Page 8 of 9 FirstFirst ... 6789 LastLast
Results 106 to 120 of 121
  1. #106
    Jul 2011
    Jarrell, TX
    Bruce, School me on offset... As I understand it, it is the distance from the center of the wheel/rim to the outside. So, if the 9.5's are 15mm and you have to add 3mm to get to the stock offset of 18mm how does 12mm work. If I do the math .25 (1/4") is 6.35mm so that makes 12mm's .47" (almost 1/2").
    My Scat Pack Web Site
  2. #107
    Apr 2018
    Rancho Cucamonga
    Offset is from the center to the inside of wheel or center of car hence why them decreasing the offset pushed the wheel away from the caliper
  3. #108
    Apr 2018
    Rancho Cucamonga
    Sorry I meant center of wheel to the hub mounting surface lol so positive is when the center portion is further in from hub center zero meaning dead center and negative center of wheel further out than hub mounting
  4. #109
    Jul 2017
    Quote Originally Posted by OZSCTPK View Post
    Sorry I meant center of wheel to the hub mounting surface lol so positive is when the center portion is further in from hub center zero meaning dead center and negative center of wheel further out than hub mounting.
    I agree 12mm moves the rim more to the outside but it does nothing for the contact issue. Plug in the numbers at Rims N Tires.
    OBTW - Had to use my Scatpack Forum ID as the LX id posting function is FUBAR for me.
    oemtech - aka Hemi_57
  5. #110
    Apr 2018
    Rancho Cucamonga
    Quote Originally Posted by oemtech View Post
    Umm yes he said the actual spoke of the demon wheel was rubbing the caliper so instead of adding a spacer they built up the material at the hub thus changing the oddest by 3 mm
  6. #111
    Apr 2018
    Rancho Cucamonga
    They essentially built the rim with that spacer built in I don’t understand your confusion
  7. #112
    Nov 2007
    If the mounting surface is dead center of the width ]=!=[ (like the exclamation point), the wheel has a "0 offset". If there is more width outboard, the wheel has a "negative" offset. If there is more width inboard, the wheel has a positive offset. The OEM +18mm offset means the mounting surface is 18mm from dead center of the width to the outboard which pushes the wheel inboard. Wheel widths are measured from where the tire seats inner to outer so the outside lip of the wheel is actually 1" wider than the wheel size (9.5" wheel is 10.5" wide overall from outer lip to outer lip). That makes a 9.5" width "0 offset" wheel 5.25" inboard and 5.25" outboard (centered). That inboard overall measurement (mounting surface to outer lip on inboard distance) is referred in the wheel business as the "backspacing" or "backspace measurement". That same wheel with a +18mm offset (more width inboard) would be the 5.25" + 18mm (0.71")= 5.96" backspacing. The same wheel with a +12mm offset would be 5.25" + 12mm (0.48")= 5.73" backspacing. There is only 6mm (0.24") difference between the OEM +18mm and our +12mm with the OEM slightly more positive (inboard) than ours.
    Bruce Rhodes
    800-824-2676
  8. #113
    Jul 2017
    Got it....
    Bruce, you got an upgrade program?
  9. #114
    Feb 2018
    NoVA
    Bruce, I sent you a PM a while ago reference wheels. Just a heads up. Thanks.
  10. #115
    Nov 2007
    Hey bravozero588,I am very sorry I missed your PM. I will find it and respond immediately.Bruce
  11. #116
    Mar 2018
    Tennessee
    315s rear - Album on Imgur
    I've been trying for a week to post these pictures. The attachment manager keeps giving me an error stating that the site certificate is invalid.
    Anyway, the valve stem on the right rear was leaking yesterday. It lost ten pounds overnight. No worries as Discount Tire fixed it for free! I did look at the wheel well when I had the wheel off. I didn't see any indications of rubbing, and we have put about 700 miles on this setup. I have not had time to pull the left wheel yet. I will at some point.
    Thanks Factory Reproductions thanked for this post
    Likes Factory Reproductions, run2jeepn liked this post
  12. #117
    Jun 2009
    South Carolina
    PM sent, as well. Thank you!
    Charger Scat Pack
  13. #118
    Jun 2009
    South Carolina
    Hey Bruce... anything?
  14. #119
    Jun 2013
    Anyone have ANY Demon reps on 1st Gen 300? please someone post or email me
    [email protected]
  15. #120
    Oct 2018
    Quote request sent via email.
