Page 35 of 35 FirstFirst ... 25333435
Results 511 to 522 of 522
  1. #511
    Nov 2014
    Thank you very much @mattrobertson and friends for the write up. Realy helped me complete my own PS cooler upgrade and oil cooler sandwich plate install. Look forward to putting them through some tough days, again thanks for your r & d and constant updates.
    [SIGPIC][/SIGPIC]
    Likes OttoPilot, Jay Z liked this post
  2. #512
    Mar 2008
    Dayton, OH
    People still doing the cooler upgrades? Cool!
    Hi Matt!
    2007 TorRed SXT/AWD: Gone, but not forgotten!
    2019 Jeep Cherokee Trailhawk
    I'm not an actor, but I do play one on TV.
    Likes d rock no ice liked this post
  3. #513
    Jun 2013
    what's she look like with clothes on?
    Likes pursuitlx liked this post
  4. #514
    Nov 2014
    Quote Originally Posted by Jay Z View Post
    You talkin to me?
  5. #515
    Jun 2013
    Quote Originally Posted by d rock no ice View Post
    You talkin to me?
    Yup
  6. #516
    Nov 2014
    Frankencooler is Here. Modular Auxiliary Cooling For The 5.7/6.1
  7. #517
    Oct 2011
    PGH
    I don't see any sort of NVH damping material in the mounting setup...is it all just hard-mounted directly to the crashbar? I believe it was addressed early in the thread when Meister's setup developed a leak, and I remember some cooler manufacturers recommended it too.
    I used Earl's coolers and their brackets which included foam/rubber/neoprene pads to help isolate the cooler from vibrations. The Hellcat oil cooler does this as well with what looks like two big rubber bushings in the mounting holes.
    You also have it mounted via just the upper ears...no concerns there? It was a potential issue that Matt solved early in the thread with simple stainless steel all-thread making it much more stable and fully supported.
    FURIOUS FUCHSIA 2010 Challenger R/T Classic A5
    Mopar // SRT // Pursuit // LMI // Zoomers // Belanger // Diablosport // Hotchkis // PowerGrid Inc // Razor's Edge // Petty's Garage // AAD // Syncro Design Works // Ridetech // Crank This! Performance-BFNY // Serious Metal Fab // Carbotech // Russell // Rennline // Stant // Joelvan // Derale // ATI Perf // Earl's // Improved Racing // Milodon // B&M // AMG // Wavetrac // ZAutoTech // Saleen SMS // Speedhut // WebElectric // Hurst
  8. #518
    Nov 2014
    Quote Originally Posted by TheFrankenberry View Post
    Thanks for pointing that out I over looked that. I think the neoprene pads would be the best bet.
    I did just mount the upper ears directly to the crash bar w/ Z brackets, my plan was to use the threaded dowels like the OG’s but ended up not feeling the need considering how sturdy it was. But hey after some miles I can easily make adjustments...but think the neoprene pads is a good immediate one.
  9. #519
    Calgary, Alberta
    You'll be fine...
    There's not enough short-term vibration loading on our rides to worry about - even if it was (directly) mounted to the engine itself. Damping / energy dissipation rules...
    Thanks d rock no ice thanked for this post
  10. #520
    Dec 2011
    Gillespie County TX
    Beautiful car and superb installation job!
    A caution is that the cooling capacity of that Mish EOC is about 16% less than the Earl's EOC on Matt's car.
    Setrab publishes the best information on EOCs. By their charts, that Mish EOC is suitable for a 260 HP engine.
    However, your design gives much better air flow than Matt's.
    This is a long way of saying, be sure to check your oil temperature under load.
  11. #521
    Nov 2014
    Quote Originally Posted by OttoPilot View Post
    Hey thanks! Good research and thank you. I figured I would go bigger if I felt the need or saw high temps but I do primarily autoX the car but i rarely plan to road course the car and won’t be anywhere close to the limits like Matt and others.
  12. #522
    Dec 2012
    Lake Elsinore, Ca
    Damn she's pretty!
    Current
    His: 2006 MSRT8, K&N CAI, built and tuned by MPR Motorsports (WhiteHemi), forged pistons and a HHP Stg 2r cam, HHP HEMITUNER TCM, Paramount Stg 2 valve body, Mopar Performance high stall converter, Flowmaster Super 10s, 180° t-stat, Tranzformer, Street Edge coilovers, 275/40/20 Firestone Firehawk Indy 500s, otherwise bone stock.
    397rwhp/399rwtq
    MOPAR360
