HOLLEY DUAL 525 LPH PUMP MODULE SYSTEM-1050 LPH TOTAL
says it'll handle 1200hp
Holley 12-176 Holley Dual 525 LPH Pump Module System-1050 LPH Total
Return or no return system Is return really needed?
looking for 800 or more to wheels when done
300S has a small fuel line
4XX stroker current eng is coming out
Getting ID 1050X injectors
Will get a Whipple Gen 5 3.0 when released
Looking at water/meth inj.
Will not run E85
Which kit? They are spendy.
13 Chrysler 300S, Stock 17 RAM 6.4 BGE with TSP Stage 4 boosted Cam, AIT 18% OD pulley, E-force 2.62 pulley(12.2 lbs boost),, Fastman 84+4 mm throttle body, 1 7/8 kooks long tubes w/hi-flow cats, 3" Magnaflow Cat-back, FTI 2800 stall, Trans by Hellraiser, Dings Racing valve body and tune, Getrag 3.73, Walbro 400LPH, DW 65# inj. aluminum rad. SRT fans. Brembo upgrade. Stage one MOPAR springs, XIX X39 22x9 +15 - 22x10.5 +22 with NITTO NT555 265/35R22 - 295/30R22
Not to dis Holley, but there's a lot of people running Fore systems, myself included. Dual hat return system, 3/8 lines, fore rails and FC3 controller.
They work without question. I am well below the ceiling on my system, for now lol
coanan thanked for this post
Just through the HOLLY out there, seem reasonably priced
Factory fuel lines are pretty small on the 300.
Was looking at the FORE system Little above my budget right now and not sure I'll need that much.
TAPPED has a system using FORE parts also, less expensive, but still up there.
delete
Fore return style is the safe/smart way to go .I have a Fore 2 pump system on my Scat . @800 wheel a deadhead will not suffice.
Lots of add on stuff to bring price up.
What did you end up with and what would you change?
List if possible. Thanks
Just picked up new ID1050X inj and a new MMX 95mm throttle body(not a real 95mm).
Price? Lets just say I saved 600.00 on the two.
Some ones project that didn't go through to finish.
New cam arrives Sat. 232/246 618/618 118 +4
Rotating assy. end of month.
Might be able to get the Gen 5 3.0 Whipple ordered middle to end of next month.
I can't figure out how to post pics of my invoice for the fuel system. if you're willing, PM your cell # to me and I will send the breakdown with part #'s
Hellcats have larger diameter fuel lines/rails etc..thats why they can make 900+ on E85 with just a BAP and injectors.. i tried to buy the fuel system from the cat my short block came from but was told by Barth Tuning (big HC,RE,Demon shop ) it wouldn't work..not sure why..
$2500 for a 1000hp fuel set up?
Damn that’s crazy. Run a Return and build your own system.
Was looking at that option and came up with about 1800.00 for return system.
Using the dual 525 kit Holley sells. A pump on both sides of tank feeding.
Aeromotive Extreme Flow EFI Fuel Pressure Regulator.
Piecing the all the hoses and fittings together. Pretty easy
Looks like Whipple has the rails included to make it work.
