Results 1 to 4 of 4
    Mar 2016
    DE
    Pre vs eagle rotators
    Are the two rotating assemblies interchangeable? I know the cam is obviously not but not sure on the crank.
    Does anyone know the piston CCs of both?
    Apr 2019
    Crank snout is definitely different to account for the larger front cover. Tone wheel on crank is different as well.
    Jun 2012
    Curtisville PA
    dont think the snout different vvt uses a spacer
    Mine:2012 Challenger Rt, 448 ci. Thitek. Bullet cam. [email protected]
    Dads:2012 Challenger Rt-6.4L swap, procharger. [email protected]
    Mar 2016
    DE
    hrmmm. well ill be picking up an eagle 5.7 in a few hours. I was thinking of putting the rotating assembly in an early block and using a non vvt cam. but i guess ill see when i tear it apart. I dont have a early 5.7 crank anymore tho. So i cant compare the two on the bench.
