Crank snout is definitely different to account for the larger front cover. Tone wheel on crank is different as well.
Are the two rotating assemblies interchangeable? I know the cam is obviously not but not sure on the crank.
Does anyone know the piston CCs of both?
dont think the snout different vvt uses a spacer
Mine:2012 Challenger Rt, 448 ci. Thitek. Bullet cam. [email protected]
Dads:2012 Challenger Rt-6.4L swap, procharger. [email protected]
hrmmm. well ill be picking up an eagle 5.7 in a few hours. I was thinking of putting the rotating assembly in an early block and using a non vvt cam. but i guess ill see when i tear it apart. I dont have a early 5.7 crank anymore tho. So i cant compare the two on the bench.
