Results 1 to 9 of 9
    Calgary, Alberta
    Purge Valve - Cooling System
    Years ago I found a nifty little device to replace the pesky 1/4" NPT HEX head plug used to properly remove all air from our cooling systems during servicing:
    Cooling System Purge Valve...
    I'm curious how many folks bought one and are using it. I'd also(!) like to know who are regularly using the purge valve to safely purge air during hot laps while at operating temps - or really(!) hot.
    Aug 2012
    iowa
    Hey Simon
    I have one and used used it when I had either the motor apart and had to redo coolant several times. Also put one on 2 other cars for a friends
    Thanks Hemissary thanked for this post
    Oct 2011
    PGH
    Me me me! Installed one of those Swagelock purge valves when the radoator was replaced and also used it for the 90k mile maintenance flush I just did. Loved not fighting with that god forsaken plug. I never burped it after any track days as I didn't feel the need to since my coolant temps were solid and stable. I'll definitely use it again when I remove the upper rad hose to install a 220A alternator and underdrive damper.
    FURIOUS FUCHSIA 2010 Challenger R/T Classic A5
    WHOA RideTech coilovers, Hotchkis sways, PowerGrid endlinks, REM & Petty braces, CTP/BFNY bushings, AAD harness bar w/ Sabelt 6pts // SLOW SMF SRT 14.2 front & Pursuit BR9 13.8 rear rotors, Carbotech pads, Russell lines // FLOW LMI F-IV intake, Belanger Tri-Y headers, Zoomers catback, Joelvan's p/s pulley & dual-pass radiator, Russell p/s cooler // GO 215mm Wavetrac diff, AMG diff cooler & BlueTops, B&M pan, Tranzformer & NoESP // AERO 392 front clip // SHOW WebElectric, Hurst, Billet Tech, RiderGraphix, Performance Pedals
    Feb 2018
    Chattanooga TN
    Like some info on that thermal graph deal. How well does it work? And where can one get one if you don't mine or I can just find some.
    2011 Dodge Charger Pursuit 113K Miles. Stock for Now.
    Cop Brakes, Cop Exhaust, Cop Suspension,
    It's the model with the big bull bar so pedestrians get out of the way.
    Calgary, Alberta
    Quote Originally Posted by CE9311 View Post
    Those particular units are 8 level +/-1% and are from Testo. Google temperature measuring strips for other types, styles and applications.
    Central Florida
    Thanks to Simon, I've had one for several years. Excellent!!!
    Old 426 guy,
    Jim
    Feb 2018
    Chattanooga TN
    Are they like a one time use deal or can they cycle within reason?
    Jun 2018
    minnesota
    I installed one when I replaced the radiator in my magnum about nine thousand miles ago. Glad I did as it made bleeding so much easier.
    Sent from my thingy with the stuff
    Apr 2013
    Buffalo NY
    I purchased one in 2018, finally got around to putting it in last month when I replaced t-stat. Works great, a little heat around that pesky plug made removal easy.
    PHATHEMI
