Results 1 to 15 of 15
    Jul 2018
    Valve Spring Height
    Does anyone happen to know the stock/factory installed height of a 2010 eagle 5.7 valve spring? I'm seeing varying info...
    Thank you so much in advance!
    Jan 2016
    1.99 in installed height.
    Jul 2018
    Thank you! Got my hands on some factory specs if anyone is interested 4E8221BF-79DC-48C0-A6C7-0EF7092657E1.jpg
    Jul 2018
    Now I also assume this would be the same for all 2009+ vehicles??
    I was looking at the P5160074 which claims to be a mopar performance spring supporting up to .625 lift and is a drop in design. They have it listed for 2011+ 5.7/6..1/6.4 (needs shims) vehicles.
    Is there any reason you all can think of as to why this wouldn’t work in a 2010 or even a 2009??? and does anyone have any experience with these or knowledge of these? I believe they are also sold as part of the scat pack/stage 2 upgrade package. Claims to be designed for their performance 5.7 camcshaft wbich I have heard is actually a comp cams possibly 270/274
    Jan 2016
    Strange-old Eagle spring factory specs at 1.99- a 2012 Eagle listed 1.81- 6.4 at 2.050.
    Jul 2018
    so you're saying you found specs of 1.99" installed height for 2009-2011? and then It switched to 1.811" installed height on 2012+ to current?
    im seeing so many diff numbers its crazy, its all over the place lol...1.800,1.811,1.95,199... -__-
    Oct 2011
    South Jersey
    Quote Originally Posted by WontStopTheFUnk View Post
    Thank you! Got my hands on some factory specs if anyone is interested í*½í¸ 4E8221BF-79DC-48C0-A6C7-0EF7092657E1.jpg
    Do you have a better pic? It’s grading and can’t see what it says.
    2006 Dodge Charger R/T - 85mm Throttle Body, AFE Stage 2 CAI, 6.1 Intake Manifold, Modern Muscle Intake Adapters, 219/223 cam, 6.1 pushrods, Manley NEXTEK Valve Springs, 6.1 Timing Chain, 6.1 oil pump, Edelbrock Titech Headers, Flowmasters X pipe, Thrush 2 Chamber Mufflers, Flowmaster Resonators and tailpipes, 3200 Edge Converter, Mopar TCM, Tranzformer, Carbon Fiber Pistol Grip Shifter, 3.06, Brake Performance drilled and slotted rotors.
    Jul 2018
    Thanks BlackAce thanked for this post
    Likes BlackAce liked this post
    Oct 2011
    South Jersey
    Just curious, where did you get this from? I haven’t found any info on install height for those springs.
    Mar 2016
    What cam are you using?
    Jul 2018
    Quote Originally Posted by BlackAce View Post
    to my knowledge/what I've been told...this is directly from dodge service tech computer :-D
    Ultimately I am looking to install the 6.4/392 cam in my 5.7. I understand, from what I have read on here and other forums, that the stock springs need to be upgraded due to coil binding and valve control...
    Jan 2016
    I got my figures at my dealer I work at. Why they vary i dunno. I would assume those Mopar springs would work. You may want to contact one of the venders for their opinion.
    Jul 2018
    Interesting? I'm wondering if 2009-2010 have their own install height or where the cut off is?? I know you said 2012 is 1.81 but im wondering if 2011 is as well. The dodge mopar performance springs state they are for 2011+ and the mopar performance guy told me last night they are rated for an install height of 1.81.... not sure if they would still be a drop in for me? He did say they include new retainers, springs, shims and I believe spring cup/valve spring seat. They sound like a good deal. wish they would work for me -__-
    Jan 2016
    A 2011 in my Chrysler manual is also 1.81- 5.7 engine.
    Jul 2018
    Hmm. I’m thinking the 2009-2010 1.99 thing might just be specific to tbose years. I wonder why they decided to go from the 1.800 on the pre eagle to 1.99 and then back to 1.81.. probably to make it tougher on us lol
    im still slightly confused on this as Im seeing 1.99/2.00 floating around the net... even your old thread here Using 6.1 intake springs on eagle head makes it very confusing
