Page 2 of 69 FirstFirst 12341252 ... LastLast
Results 16 to 30 of 1023
  1. #16
    May 2014
    Virginia Beach, VA
    Ugly welds and that merge collector.....yikes!
    But still better than shorties.
    Sent from my SAMSUNG-SM-N900A using Scat Pack Forums mobile app
    2006 Dodge Charger Daytona TorRed #1354, SRT Heads/Intake - ARH Long Tubes - Spartan Plus Cam - Magnaflow - 3.91s - 411rwhp/410rwtq
    Acceleration video: https://www.youtube.com/watch?v=MLey...aubWU9N6ezVy7g
    I detail cars in the Virginia Beach/Norfolk area! 757-435-4027
  2. #17
    Nov 2014
    what's wrong with the merge? I would have to say the welds are not much worse then the oem 6.1 manifolds i had inside the ports.
  3. #18
    Nov 2014
    Quote Originally Posted by tokinmoenugz View Post
    Those part numbers are $400-$900, any leads on cheaper mids?
    Sent from my XT1254 using Scat Pack Forums mobile app
    This is the problem. For what companies charge for the mids I'll prob end up cutting and welding my stock mids. I was also thinking of cutting that flange and bulge off the headers and using the pacesetter mids as I believe they are the cheapest I found, but they don't have cats:(
  4. #19
    Nov 2014
    https://www.ebay.com/itm/281765059731 these bbk might bolt up. Not sure about the flange size though. They say 2.75 inch and the collector is supposedly 3" on the headers. I'll check the headers tomorrow. Does anyone know if someone using bbk mids on kooks headers?
  5. #20
    Dec 2016
    Charlotte NC
    Quote Originally Posted by BradJo9 View Post
    I would think a muffler shop could make up a set of catless pipes for less than that.
  6. #21
    Dec 2016
    Quote Originally Posted by 4DoorMuscle View Post
    I was thinking about that too
  7. #22
    Oct 2011
    South Jersey
    I bet you have always wondered about those eBay headers
    I was talking to an eBay seller a few months back and they were supposed to be coming out with a set of high flow mids for about $125 I believe. They were supposed to be released around June. I don't recall the who the seller was but it was one them who offered cheap aftermarket headers. It could be them. I'll have to go back through my messages and see who it was.
    I would look every so often to see if they were available but I haven't seen them listed.
    2006 Dodge Charger R/T - 85mm Throttle Body, AFE Stage 2 CAI, 6.1 Intake Manifold, Modern Muscle Intake Adapters, 219/223 cam, 6.1 pushrods, Manley NEXTEK Valve Springs, 6.1 Timing Chain, 6.1 oil pump, Edelbrock Titech Headers, Flowmasters X pipe, Thrush 2 Chamber Mufflers, Flowmaster Resonators and tailpipes, 3200 Edge Converter, Mopar TCM, Tranzformer, Carbon Fiber Pistol Grip Shifter, 3.06, Brake Performance drilled and slotted rotors.
  8. #23
    Nov 2014
    Might be the way to go, I'll prob add some cats though
  9. #24
    Nov 2014
    Looks like if you want cats your gonna be above 400$ there are a few non catted options for $250ish
    Flowtech 13133FLT 06-14 CHGR/CHLGR/MAG/300 6.1L OFF-ROAD MID-PIPES | eBay
    https://www.ebay.com/itm/122345751814
    These will still need adapted to the 5.7 exhaust though, prob still cheaper to let an exhaust shop fab some.
  10. #25
    Nov 2014
    Wondering if something like this could be used to tie in from headers to stock mids. Would lose the cats unless they were cut and re welded in.
    Would need 2 bolt flanges and cut and weld also an o2 bung. Now I need to see where the headers exit is positioned compared to where the stock mid is placed after the cat. If I can do it myself for $60 or so I'd be thrilled.
    I do have a welder and enjoy using it more then I should lol. When I first started welding I got severe skin burns from welding all day in a Tshirt with googles. I didn't know any better, Live and learn. Safety first
  11. #26
    Oct 2011
    South Jersey
    You have to worry about the bends and location but if it works add an X pipe then add proper length straight pipes and you should be set
  12. #27
    Nov 2014
    I don't see these making it to the center of the car to use an x pipe like that they don't look anywhere that length. I'm thinking just after the cats somewhere before they turn in towards the center
  13. #28
    Nov 2014
    I'm going to give the headman extensions a try. I'll send them back if I can't see a way
  14. #29
    Mar 2017
    I seen these ebay headers and oftentimes wonder if they are exported by the same Chinese company Flowtech uses with the difference is that Holley installs a far better merge collector? Flowtech headers are around $570 without the mids and also are 1 7/8".
  15. #30
    Nov 2014
    In the image above where I posted the flowtech mids you'll notice the flange is different so idk.
