Page 6 of 6 FirstFirst ... 456
Results 76 to 81 of 81
  1. #76
    Jul 2011
    Jarrell, TX
    Look what showed up today?
    OBTW - I ordered 3 extra. If you need one PM me.
    My Scat Pack Web Site
  2. #77
    Nov 2010
    I’ll take one dale. Pm me your pp
  3. #78
    Mar 2016
    N. GA
    Those do look nice.
    Using the brake bleeder I have a hose running into a bucket in front of the car. To fill I use a D-Cell battery transfer pump to fill the block at the t-stat opening then pop it in, then pump it into the top rad hose until it fills and pop it on, then the reservoir and start up.
    The Stant SuperStat I use has a check ball bleeder built in that's placed at 12 o'clock. I haven't had an air issue so far.
    2013 Dodge Charger R/T Plus, Edelbrock E-Force 2300TVS 6.4 PSI, Mustang-Dyno Tuned 418hp/430tq, 3.06:1, Severe Duty Radiator, Dual Fans, OE Oil Cooler, Pursuit BR9 Brakes, Corsa CatBack, Bilstein Dampers, Catch Can, AlfaOBD enabled Sport Mode & SRT Pages, Fogs on w/High Beams, Add Reverse Cam & Auto Dimming & Tilt in Reverse Left Door Mirror.
  4. #79
    Jul 2017
    Texas
    Quote Originally Posted by Renfrick1 View Post
    PM to you
    Sent from my SM-G965U using Tapatalk
  5. #80
    Calgary, Alberta
    Quote Originally Posted by oemtech View Post
    PM to you
    You're selling one to yourself?
    Thanks BryGuy thanked for this post
  6. #81
    Jul 2011
    Jarrell, TX
    DOH homer... fat fingers and small ph screen
