Page 3 of 6 FirstFirst 12345 ... LastLast
Results 31 to 45 of 81
  1. #31
    Oct 2015
    If you have a 6.5mm Allen head socket - try it. My Allen headed sockets go from 6mm to 7mm. Do you have a torch? Heating up the surrounding aluminum can help, as it expands at a significantly greater rate then the metal NPT plug...
    My set jumps from 6-7mm too, I was going to buy a 6.5 somewhere. Maybe I'll try the torch. I appreciate the input.
    2010 SRT Challenger M6 with a Magnuson 2300, cam & heads...tweaked by BFNY and tuned by AJ.
  2. #32
    Sep 2009
    Bainsville Ontario
    Try a 1/4" key. = 6.1mm
  3. #33
    Calgary, Alberta
    I think he did already; to the OP, if you have rounded the HEX in the NPT using the 1/4", you might try hammering in the metric 7mm and see if that works...
  4. #34
    Oct 2015
    Yeah, I tried a 1/4" in perfect condition, but it wouldn't work. A 7 is too big, so I'm going to look for a 6.5 and heat up the pump.
  5. #35
    Calgary, Alberta
    Quote Originally Posted by 2010SRT View Post
    Pretty sure you won't find a 6.5mm Allen key. Another idea would be to carefully grind down the tip on a 7mm Allen key such that when you hammer it in, that wedge-fit along with a good blow from a hammer to loosen will do the trick...
  6. #36
    Oct 2015
    Strike 2 for me. Hammered a 7mm Allen wrench into the head and applied heat....a few times...and tapped it with a hammer. Just stripped out the head again. Now, its just a larger round hole. I guess I know why the previous owner wasn't able to properly bleed the system. They couldn't get this damn bolt out! The bolt seems really soft, almost like aluminum or stainless.
    My easy outs are either too small or too big. I'm going to grind some off of one and try it again.
    This is much more difficult than it needs to be.
  7. #37
    Calgary, Alberta
    I agree - the engineers could have come up with a better system - if not just a better insert that would be R&R'd easier :^/
    So you have easy-outs, that's good. Last time I removed one for a customer I drilled into the HEX (into the coolant passage - nothing behind) with a 1/4" bit. I then used the appropriate-sized easy-out. Came right out...
    EDIT; trying to cut down an easy-out would not be easy, it's hardened steel...
  8. #38
    Oct 2015
    You drilled through the Allen head into the pump? You weren't worried about shavings entering the coolant? Nothing to damage back there?
  9. #39
    Calgary, Alberta
    The NPT fitting is above the pump and opens into a large cavity. Shavings are coming out - not going in :^)
    Drill until the bit has pierced the NPT fitting, then use a large enough easy-out such only the first 30% of the tool is beginning to cut into the HEX portion of the NPT. Make sure(!) to support the ratchet and easy-out to avoid(!) side-loading the tool. The last thing you need is to fracture part of the tool inside the NPT remnants...
  10. #40
    Calgary, Alberta
    Added more info above...
  11. #41
    Dec 2012
    Lake Elsinore, Ca
    Side note has anybody found a dealer that has an ounce of sanity as far as pricing? I've called my local dealer several times and I keep getting the same astronomical price...next bet is waiting for one to pop up on eBay.
    Current
    His: 2006 MSRT8, K&N CAI, built and tuned by MPR Motorsports (WhiteHemi), forged pistons and a HHP Stg 2r cam, HHP HEMITUNER TCM, Paramount Stg 2 valve body, Mopar Performance high stall converter, Flowmaster Super 10s, 180° t-stat, Tranzformer, Street Edge coilovers, 275/40/20 Firestone Firehawk Indy 500s, otherwise bone stock.
    397rwhp/399rwtq
    MOPAR360
  12. #42
    Oct 2015
    Quote Originally Posted by Tikibeast View Post
    I paid less than $17 for mine. If enough guys need them, I can order some and ship them for those who need it.
  13. #43
    Dec 2012
    Lake Elsinore, Ca
    Thank you, I may take you up on that, after looking at your price and previous prices I think I'm going to call them again and pick a bone with their manager seeing as I've thus far been unable to find a phone number for a head office.
  14. #44
    Oct 2015
    Maybe I'll sell you mine. I can't get a right angle drill in there to drill it straight. I've round out the head by using a 6mm, 7mm and a 40 or 45 torx bit. Between my boats, cars & trucks, I've done my share of tinkering and this damn bolt is one of the biggest pains I've had. I'd like to meet the guy who last installed it.
  15. #45
    Dec 2012
    Lake Elsinore, Ca
    Lol keep at it, tear it down if you have to, it's a good little preventative maintenance solution for those of us that actually drive these things as intended.
