Page 2 of 24 FirstFirst 123412 ... LastLast
Results 16 to 30 of 360
  1. #16
    Calgary, Alberta
    Test-fitted 08' and earlier OEM fuel rails (RT/SRT) and OEM injectors; the oil fill neck on the port side lifts that rail (only) ~.08" so shims would be required. The 09' and newer rails should fit without shims...
  2. #17
    greasy cardboard box
    so that's what you've been up to. man, that's way more ambitious that anything i would ever undertake.
  3. #18
    Nov 2008
    Murrieta, Ca
    Very nice, Hopefully we'll be able to utilize this and make more power above 6000 rpms........ Activation will be on an rpm switch or tach wire?
    6.1 swap......
    1.599 60' 11.7 1/4 @ 115 mph
    4250 lbs
    "you're going to come across people in your life
    who will say all the right words at all the right
    times. But in the end. it's always their actions
    you should judge them by. it's actions, not
    words, that matter."
  4. #19
    Charlotte, NC
    interesting simon.
    The Really Old: Stock 5.7 Bottom End | Lead Foot | 11.861 @ 112.76 1.63 60'
    The Old
    : Forged Arrington 6.1 | MMPG Top End | Paramount Drivetrain | 11.67
    The New:
    6.1 based 392 | 3.6L Kenne Bell | Thitek Heads | Paramount Trans/'Verter | DSS 9"/Axles/CF Driveshaft | 10.21 @134
  5. #20
    Calgary, Alberta
    ...believe it or not this will be much simpler (and way less labor-intensive) than the previous manifold project :^)
  6. #21
    Feb 2011
    PALMDALE
    Whats up man looking into getting one of these....have u been able to run it yet???
  7. #22
    Calgary, Alberta
    I asked SRT Engineers a couple of operational questions, G's response:
    "The SRV actuates between 4800 and 4900 rpm. It adds a huge amount of area under the curve below 4800 and really adds to the performance of the MTX vehicle."
  8. #23
    Feb 2011
    PALMDALE
    Would you be able to PM me on the.details of how you activated your runners...I have an idea of how to but would like to see how u did it....also would using a spacer such as cams eagle manifold spacer or a thermal spacer allow the manifold to bolt on without any modifacation?... I'm pretty sure I'm gonna pull the trigger on this as my stroker motor was just finished and is in breaking period......
  9. #24
    Nov 2008
    Murrieta, Ca
    I figure the manifold to be actuated right before the HP takes over the TQ at 5250, sure enough that where it is. Just like setting up a Torque converter, trans brake and short intake runner for a carburetor set up. Right before the HP takes over. Give or take a couple a 100 rpms...................... To see where the sweet spot is.
  10. #25
    Calgary, Alberta
    Huh?
  11. #26
    Feb 2008
    Eastern Shore of Maryland
    Simon will the two metal tube heater/coolant lines that run under the intake going to interfer with the 6.4 intake?
    2010 Challenger SRT /M6 with an ARI 440 rebuilt by Charlie's Machine, Apache heads Ported by Craig of Thitek, Ported 6.1 Intake by Modern Muscle, 90mm TB by ARI, TTi 1-7/8" Long Tubes, Zoomers 3" Exhaust, LMI 4" CAI, Trinity Tuner, BC Racing Suspension, Zeitronix Wideband, Hotchkis Sway Bars and Tuned by Brent @ DTP Racing.
  12. #27
    Calgary, Alberta
    Good question Jeff; another thing to check when the new stroker is finished...
  13. #28
    Feb 2010
    San Diego
    can always reroute the heater lines like they do with the top mount blowers
    So what if I drive a stationwagon, my other car's a rwd 540hp, Supercharged Hemi that will blow your doors off, oh wait thats this car.
    '07 Magnum SRT-8: Diablo Predator, QTP Cutouts, 180* Jet Tstat, BT catch can, and underhood dress up kit, Hurst Shifter, custom switch plate in center console and ashtray,Silverbox, Killerglass, custom radiator from Joelvan. S4 Labonte Water Meth Kit, Kenne Bell 3.6LC,SHR Viking, in the works DSS 1400hp shafts on a wavetrac diff
  14. #29
    Calgary, Alberta
    True, or just install a soft line...
  15. #30
    Mar 2011
    so does the actually either stay fully open or fully closed in normal operation or is it actually variable???
