Analog issues are most commonly ground based issues.
If there is NO change in the signal coming from the analog you may have the wrong channel configured.
You can test with a multi meter at the tip of the analog cable to see if its getting a 0-5V sweep from the sensor. If not, trace it back until you get that signal and you should find the issue.
Please let me know who you were working with on our end or the case number you have and I will look into that.
Thanks
