Results 1 to 7 of 7
    Sep 2016
    Right front tire
    Right front tire scraping at 50mph +when going over dips in the road? Any help
    Nov 2007
    NorCal
    Stock ride height car?
    Pull the wheel and see where the rub is (unless you can get your head under there with a flashlight).
    X E Ryder
    Just Another Motorhead, Really.
    (midlife crisis activated)
    Sep 2016
    Quote Originally Posted by X E Ryder View Post
    Any suggestions what I should do
    Mar 2017
    Bedford, Texas
    We don't know anything, other than your tire is scraping. We don't know what vehicle, we don't know what wheel/tire combo you're running.
    All those things are pertinent to getting a solution to your problem.
    Sep 2016
    295/45/20, strut has been replaced, after still scrapes not as bad, right side only
    Jul 2017
    Did this start after installing new tires? What is your back spacing on the wheel?
    295 is a pretty big tire on the front, my local tire idiots installed my 295 from the rear on the front and the 265 on the rear. The front right scraped and I went back right away after discovering the issue.
    2012 300 SRT8: 22" Vossen wheels, Nitto 420 265/35/22 front and 295/30/22 rear, SLP Bigmouth II exhaust, Tuned by Hemifever, Mishimoto 180° stat, Legmaker Tru CAI, Billet tech Oil Catch can.
    Mar 2017
    Bedford, Texas
    If you have a 295/45/20 on the front, you are going to scrape. Spaced wheels with 275/40/20's will scrape the outside of the tire on the fender liner....even at stock ride height.
    If it IS a 295/45, that's almost 2" taller and 2" wider than stock. I'm actually shocked it cleared the strut/ knuckle bolt
