New Hellcat Owner
11K views 13 replies 10 participants last post by  Heat00
#1 ·
just traded 2016 scatpack for 2018 B5 blue Hellcat what a Beast! any suggestions on performance mods?
#8 ·
Rubber, rubber, and more rubber. The primary issue with these cars isn't insufficient power. It's ability to put it down. First (start to) fix the traction issue, then look at other things. Unless/until you put drag radials on the car, track it, and bounce the rear, you don't need a driveshaft upgrade.
#11 ·
This is interesting, I can’t even get traction in my 392’s... what is the solution wider rims in the rear ? And then you’re saying it will cause other issues with drive shaft?
#12 ·
This is interesting, I can't even get traction in my 392's... what is the solution wider rims in the rear ? And then you're saying it will cause other issues with drive shaft?
Only on the Hellcats Joey. We don't make enough power stock to break them lol.
Yes, wider rims and tires WILL help your traction. I pulled a 4.1 0-60 on my street tires recently [emoji16]
#14 ·
That’s not a bad time... I couldn’t break 4.5 and 4.6 on my first scat and Daytona but the new scar hit 4.2 somehow lol
