Page 1 of 4 123 ... LastLast
Results 1 to 15 of 49
    Jun 2020
    Dynamics Package vs. Widebody Scat Pack
    I'm debating between a standard body Scat Pack with the Dynamics Package and Adaptive Suspension vs. a Widebody Scat Pack.On paper, they seem similar in that they both get the 6-piston Brembos, flat bottom steering wheel, adaptive suspension, and wider tires (albeit 275's vs. 305's). I know the Widebody has different suspension tuning, but does anyone have first hand experience with regards to how differently they actually drive?I realize the Widebody can fit wider tires, but I believe on the 9.5" wheels that come on the Dynamics Package, I can upgrade the rears to 295's so probably not a ton of difference between 295 vs. 305 I'd imagine. On the fronts, however, I believe 275 is as wide as you can go without rubbing on the standard body. Not sure how big a difference 275 vs. 305 makes for the fronts.The way I'm looking at it, it's $3k additional for the Widebody vs. the Dynamics + Adaptive Suspension, and I'm wondering if there's an actual functional difference, or whether it's really more aesthetics.
    Sep 2019
    I was debating the same things. I went with standard body with dynamics package and adaptive damping suspension. I did this because I wanted plus package as well. So it just worked out better financially for me at this time. I don’t know that this helps you at all (probably not) but thought I would just share my story.
    So can you put 295 on the 9.5 wheel? Good luck with your decision. It is a tuff one.
    Nov 2015
    Eastern NC
    The question you need to ask yourself, what are your plans for the car? If you aren't seriously considering tracking the car, save some money and get the standard.
    If you are considering tracking at all or just like the look of the wide body. Go for it. You won't regret it then.
    Sent from my SM-G975U1 using Tapatalk
    Previous:
    '17 Camaro 2SS A8
    Likes estar1, Heat00 liked this post
    Dec 2016
    Ft. Lauderdale, FL
    I’ve had both and my most recent is the Widebody but it was mostly just the look. Some don’t like it but if you put them side by side you’ll see the difference, to me the stance and overall look is much nicer. And yes you get different suspension , even if not on a track, I do notice a difference from my first scat packs in the handling department. That being said, I get no better straight line traction really.
    '19 Challenger Wide body Scat Pack B5; '19 Scat Pack F8 Green; '18 Audi SQ5 Daytona Grey; '18 Daytona 392; 16 Scat Pack Granite; '15 Durango R/T Blacktop; '14 Volvo S60R Rebel Blue; '12 Audi Q5; '10 Mustang; '08 BMW E90 M3; '07 BMW 335I Active Autowerks ...
    Likes SuperSound, estar1 liked this post
    Dec 2016
    Ft. Lauderdale, FL
    I know it’s a challey but same concept, the 11” rims are much deeper too which is the look that I love
    Aug 2018
    As soon as the widebody came out, I traded in my 18 with the Dynamics. Basically the same car. Traction is way better at launch but man the stance. So Bad Ass
    Likes Heat00 liked this post
    Jun 2013
    The F8 looked way better stance wise imo. If you're truly after stance it handling, why not get basic and upgrade to a REAL adjustable suspension?
    Jun 2020
    I just placed an order for the car, and ended up going with the standard body Scat Pack with the Dynamics package + adaptive suspension. If cost were completely not a concern, I might've chosen differently, but as I started to build out the car, I had to weigh whether the incremental cost of each option was going to be "worth it" to me, and ultimately, had the draw the line somewhere. Otherwise I probably could've justified the costs all the way up to a Hellcat. So, I feel like given what the car will be used for, I still get most of what I'd want with the Dynamics Package, while still saving about $3k in cash. If the stock 275's seem inadequate, I can always upgrade to better tires or even put 295's on the stock rears, and that should help.Thanks again to everyone that provided their input - much appreciated!
    Sep 2019
    Quote Originally Posted by kyoung05 View Post
    Nice, what color did you end up ordering? Did you go ahead with the adaptive damping suspension? Congrats man! Mine is at dealership. I take delivery Monday. I’ll post some pics when I do. Make sure and post yours too.
    Oct 2019
    So 295 will go on the stock rears in place of the 275?
    That’s good to know. Wish they would fit up front too.
    Jun 2020
    Quote Originally Posted by estar1 View Post
    Thanks!
    I went with Go Mango - It definitely wasn't a color I was considering at all initially, but it grew on me. My initial color choice was F8 Green, then Frostbite or Indigo Blue, and I finally landed on Go Mango. I think the brightness of the color really pops (at least based on the pictures and videos I've seen), and the Scat Pack is a loud, brash car so it seemed kinda fitting. We also have a very big, blind cat named Mango who has a ton of energy but can't turn so well, so it seemed a bit fortuitous.
    In terms of tire size, yes, from what I've read 295's would fit on the stock 9.5" wheels in the back, but would be too wide to fit on the front without rubbing. I'm still debating whether I want to run a square setup so that I can rotate the tires and get a bit more miles out of them, or whether the added traction from the 295's in the rear are worth the trade off in tire life.
    Jacksonville, FL
    Will 315’s or 325’s fit the Widebody?
    Terry
    2019 Octane Red Charger GT
    2020 Charger Scat Pack Widebody
    Oct 2019
    Not sure what part of the country you are in, here in Vegas when it rains it’s like ice from all the oil coming up. The 275 did well but I also feel it could do better.
    I really want to go wider but not sure if I should go with a split set and get new wheels for some 315’s or do the 275/295 keep stock wheels. It’s a lease sooooo that’s a factor as well.
    I love my car but never knowDynamics Package vs. Widebody Scat Pack
    Sep 2019
    Thanks!
    Sep 2019
    Thanks!
    Love that color as well. Like indigo it doesn’t always look the color it is. To me it appears red sometimes. What other options did you go with if any?
