Results 1 to 13 of 13
    Aug 2019
    Largest wheel/tire and at what offset for safe Fitment?
    Going to keep my stock 9” wheels for my winter tires and with some Black Friday sales going on I’d like to snag a good deal on some wheels.
    I’m kinda at the analysis paralysis stage after reading through older posts but some observations I’ve made are that 315mm tired seem risky. Some rub, some don’t.
    Am I safe running 10.5” or 11” rear wheels with 305mm tires? For offset it seems like around 25mm should be good correct? I have the standard brembos if it matters.
    For fronts I was looking at 10” wide wheels with 275mm tires. Any Fitment issues with this set up?
    Sorry to beat a dead horse, but the more I read the more differing opinions I read and was getting confused.
    I’m looking at wheels from Ferrada, variant, or rohanna.
    Mar 2017
    Bedford, Texas
    Stay with 9's up front. Too far in rubs the spindle, too far out rubs the fender well on bumps and full lock turns (most of the time). There IS a perfect offset but I have no clue what it is.
    The rears, honestly, with 10.5's or 11's, +18 - +22mm is the range you want to stay in. You already know my 10.5's/ +25mm have a 6mm spacer, but I run that more for peace of mind (it also lets my Drag Radials clear no issues, so I just leave them there).
    The difference between 305 and 315's is less than 1/4" on each side, so there really isn't much difference in traction or looks. They're both wide lol
    Aug 2019
    Maybe I’m not thinking of this right. If you say 18-22mm offset is what to shoot for, wouldn’t your offset be closer to 31mm (25mm offset+6mm spacer).
    Jun 2018
    Quote Originally Posted by WhiteKnucklePete View Post
    You are actually decreasing positive offset pushing the wheel away from the hub. So more like 12-18mm+ offset
    Aug 2019
    Ok, I thought moving the wheel mounting location farther away from the center of the rim was an increase in offset. Adding a spacer would push the wheel further out towards the street and would increase that distance. So how does a spacer decrease offset?
    Larger the offset the more risk you run of hitting the outer fender, the less offset you run you increase rub chances inside the wheel well correct?
    I would also think with a wider wheel, you will get more concavity to the look of the wheel as well correct?
    Jun 2018
    No offset works like this I’ll use a picture to explain it.
    Likes calcruz31 liked this post
    Jun 2018
    Quote Originally Posted by Eric40962005 View Post
    Adding a spacer moves the whole wheel out same as moving the center of your wheel inward. Hence decreasing POSITIVE offset.
    Aug 2019
    Severn, MD
    Factory Reproductions guys told me with a 10.5" +25 in the rear and a 305, no spacer needed, if you want 315, then a 3mm spacer is needed.. I have the dynamics package with 9.5 +15 in front and have a stock 275 that runs fine. I just got a set of FR's from a member here that are 9.5 +15 and 10.5 +25 and have 275's on front and 315's on rear... member told me he did not have any rub except every once in a while. The tires are Atturo's.. Unfortunately, a 315 in one brand is not exactly the same as another brand.. I will probably get the spacer anyway just for piece of mind, and I will be switching out to toyo tires once these run out.
    2019 Charger Scat Pack ---- 2018 Ford F150 Platinum ---- 2018 Audi SQ5 (wifey)
    Nov 2013
    South Florida
    Stick with 9" in the front. 10" will work as well with 315 or 305s.
    Here is how the 305s look and I cant hardly tell the difference between the 315s I had on previously.
    Since my setup is widened to the inside I am running a 10mm spacer with extended studs.
    2006 300c SRT8
    PWR Ported Heads | HHP Stage 2R Cam | 3.91 Getrag | GTP Ported Intake Manifold | Kooks Longtubes | Corsa Sport / SRT Resonators | AMG 8 Piston Brake Calipers | Hemituner 6,800 TCM | BT Catch Can | LMI True CAI V2 | Tranzformer | MM 87mm TB | Johan Tuned | REM Adjustable Endlinks & Front/Rear Shock Braces | 33/22mm Front/Rear Sway Bars | Michelin Pilot Sport 4S 305/35/20 & 275/40/20 | 10" Widened Oem Wheels | LC-2 Wideband Analog Output to Trinity | Mishimoto Full Aluminum Radiator
    Likes ronan978, UpInSmoke liked this post
    Apr 2019
    Quote Originally Posted by BM_SRT View Post
    My 19 Scat Pack came with 9.5" x 20 wheels all around with 275 tires. I have the 6 piston Brembo's up front. 4 piston Brembo on the rear.
    Sent from my SM-G965U using Scat Pack Forums mobile app
    Nov 2013
    South Florida
    Quote Originally Posted by 1978 NYB View Post
    The offset of those is lower to accommodate the extra width up front. I think the op wanted about 25mm but the 9.5" can accommodate a 285/35 for a bit more tire up front. The 9" can too with a 3mm spacer.
    Oct 2018
    Jacksonville, Fl
    Take a look at 2016 Dodge Charger Fitment Gallery 20in Wheel Diameter | Fitment Industries The site has a pretty good selection of wheel/tire combo's for our cars in the gallery.
    I'm running Vertini 20x11's (21et) with 305's in the rear and 20x10's (26et) with 275's in the front.
    If you look on the Hellcat forums, there are a few guys that post pretty regularly advertising wheel/tire combos for decent prices. I picked mine up from a guy named Jon at Best Wheel Deals and he was a huge help. I wanted deep and wide and he got me exactly what I wanted at a price point I was good with.
    Good luck!
    Paul
    16 Charger Scat Pack
    HC airbox/tube, catch can, 19 grille, Ikon Rear Diffuser, Vertini RF 1.3 20x10/20x11, Tazer
    Feb 2019
    Southeast Michigan
    Quote Originally Posted by PaulMc View Post
    Likes ODB, PaulMc, Billmo, punisher69 liked this post
