Page 3 of 3 FirstFirst 123
Results 31 to 41 of 41
Thread: wax question
  1. #31
    Feb 2012
    NuFinish for me twice a year for my DD
    Sent from my SM-G950W using Scat Pack Forums mobile app
    Thanks Heat00 thanked for this post
  2. #32
    Feb 2019
    Southeast Michigan
    Quote Originally Posted by LuvinMyCharger View Post
    But it's the once a year car polish....
    2019 Charger Scat Pack
  3. #33
    Feb 2012
    Quote Originally Posted by snobrdrdan View Post
    Just incase I missed a spot or 2 wax questionwax question
  4. #34
    Jul 2011
    Jarrell, TX
    This my way...
    Plan A - Wash and no wax after drying.
    1. Car wash soap
    2. Micro Fiber wash mitt
    3. Calgon - water softener
    4. Black Magic Wheel cleaner
    5. Ice Clean n Shine
    6. Black Magic Wheel Shine
    7. Micro Fiber drying towel
    8. $5 Leaf Blower
    I use car wash soap & Calgon to hold down the water spots. The leaf blower gets rid of 90% of the water. The Clean & Shine removes any leftover water spots. I spray it on as I wipe the leftover water from the leaf blower pass. Tire cleaner gets rid of the grime and brake dust. Lastly a little tire shine for bling.
    Plan B - Light dusting & Detail Spray
    1. California Duster
    2. TW Ice
    3. Micro fiber polishing cloths
    Plan C - Wash & Quick Wax
    1. Clay bar
    2. Zymol Cleaner Wax
    3. Palm ROB & 5" foam pad
    4. Micro fiber polishing cloths
    Plan D - Wash, Cleaner, Polish & Seal
    1. Clay bar
    2. Optimum Cleaner - Polish - Sealer
    3. HF Variable Speed ROB & 6", 5" & 3" foam pads
    OBTW - The pads will be replaced as the have served me well.
    Results - Outside
    Inside
    My Scat Pack Web Site
    Likes punisher69, Heat00 liked this post
  5. #35
    Jul 2011
    Jarrell, TX
    OBTW -If you have a Gauze type air filter don't buy that expensive cleaner as the Black Magic wheel cleaner (Wesley's Bleach White) is the same stuff.
  6. #36
    Jul 2011
    Jarrell, TX
    Well as long as we are on the Wax On n Wax Off.... We need to clean the the windshield.
    1. Never use 0000 Steel Wool or any other abrasive pad.
    2. Don't wax it either if you want your wipers to work as designed.
    I have tried dang near every cleaner, spray know to man and finally come up with my own formula.
    1. 20 oz spray bottle
    2. RainX
    3. Wink Rust Remover
    4. Windshield washer fluid.
    5. Clay Bar
    6. Blue shop towels
    Mix 1 oz of RainX & 1 iz of Wink with 18 oz of Windshield washer fluid.
    Next clean the windshield with the clay bar a water with about 3 drops of dish soap.
    Now apply a spray of Oemy's Cleaner and wipe dry. If you have a some left over haze, spray with just a touch of your soap/water solution and wipe dry.
    The haze is due to the RanX. The Wink will remove most hard water spots.
    DO NOT use this on anything else, especially window tint.
    NOTE - I use to use Micro Fiber cloths but found that Blue shop towels work the best.
    Now that you are all ready to go roundup all your supplies... Forget about it as I found a much simpler solution.
    Invisible Glass glass cleaner. I still clay bar the windshield now and then to get the grim off the the glass cleaner does not get.
    One last tip, got this from a buddy that worked in glass shop... You can polish your windshield with Cerium Oxide polish.
    I used my HF ROB and 3" pad.
  7. #37
    Mar 2018
    F11 top coat is what I use makes a huge difference here in Florida.
  8. #38
    Mar 2018
    Dec 2016
    Ft. Lauderdale, FL
    Good stuff thanks!
    '19 Challenger Wide body Scat Pack B5; '19 Scat Pack F8 Green; '18 Audi SQ5 Daytona Grey; '18 Daytona 392; 16 Scat Pack Granite; '15 Durango R/T Blacktop; '14 Volvo S60R Rebel Blue; '12 Audi Q5; '10 Mustang; '08 BMW E90 M3; '07 BMW 335I Active Autowerks ...
  10. #40
    Aug 2017
    This thread = gold. I need to do paint correction soon,cars clear is looking a little harshwax question
    Likes Heat00 liked this post
  11. #41
    Dec 2016
    Ft. Lauderdale, FL
    Well as long as we are on the Wax On n Wax Off.... We need to clean the the windshield.1. Never use 0000 Steel Wool or any other abrasive pad.2. Don't wax it either if you want your wipers to work as designed.I have tried dang near every cleaner, spray know to man and finally come up with my own formula.1. 20 oz spray bottle2. RainX3. Wink Rust Remover4. Windshield washer fluid.5. Clay Bar6. Blue shop towelsMix 1 oz of RainX & 1 iz of Wink with 18 oz of Windshield washer fluid.Next clean the windshield with the clay bar a water with about 3 drops of dish soap.Now apply a spray of Oemy's Cleaner and wipe dry. If you have a some left over haze, spray with just a touch of your soap/water solution and wipe dry. The haze is due to the RanX. The Wink will remove most hard water spots.DO NOT use this on anything else, especially window tint.NOTE - I use to use Micro Fiber cloths but found that Blue shop towels work the best. Now that you are all ready to go roundup all your supplies... Forget about it as I found a much simpler solution.Invisible Glass glass cleaner. I still clay bar the windshield now and then to get the grim off the the glass cleaner does not get.One last tip, got this from a buddy that worked in glass shop... You can polish your windshield with Cerium Oxide polish. I used my HF ROB and 3" pad.
    this is also great stuff thanks... I happen to use the rain x also but I got the one with the glass cleaner built in, works perfectly well, cleans and protects all together... I'm going to try to clay bar the window as that's a great idea...
