Results 1 to 6 of 6
    Oct 2015
    Arkansas
    PLEASE HELP: Strange Engine Noise in 2017 Dodge Charger R/T
    Please help me identify this noise. The car has about 37,000 miles on it. The noise changes with engine speed. Spraying WD40 on belt does not change sound. All residue seen on engine is WD40. I'm trying to save myself some diagnostic work here. So if you've seen this before, please let me know what you found out. Thanks so much for your help.
    2006 Dodge Charger R/T Daytona - Top Banana 2584
    BBK Cold Air Intake · JBA Stainless Shorty Headers · DiabloSport CAI 93 OctaneTune · Mopar Chrome 20's
    2017 Dodge Charger R/T Premium
    Jan 2016
    This is a easy one - Im a dodge tech. This is a bad water pump bearing- make a froggy sound. They have extended water pump on some late models. Have dealer check.
    Likes BorisGT, HandyCharger liked this post
    Apr 2017
    Redlands, CA
    Is the A/C or defrost on? if it is try turning it off, it might be the compressor clutch cycling on/off and chattering? you can also try removing your accessory belt, then start the car and see if the sound went away,only run it for few minutes as the water pump will not be spinning and neither will the alternator, might also be a bad idler pulley too. do you have a really long screwdriver or mech stethoscope to touch to some things and diagnose further?
    [CENTER]2006 300C SRT8[COLOR=#333333][FONT=Verdana]
    2017 Hellcat exhaust / MF High flow cats / LMI Air Hammer / Mopar Perfomance TCM / Diablo Trinity / Johan (Diablotoona) Tuned / Pedders TrackII springs and shocks / '16 Scat pack front sway bar 32mm / Bwoody Hellcat front end links / Arrington billet strut tower brace / UPR pro series bump stop kit / Custom Air-Oil separator / Mishimoto 180* T-stat / Speedlogix billet front adj control arms / HyLift Johnson roller lifters -What "Hemi tick"/ + HRF
    Thanks HandyCharger thanked for this post
    Jun 2016
    Georgetown, Tx
    Water pump. Replaced mine around 31-33k miles.
    2016 Charger Scat Pack
    LMI Intake
    3.70 gears
    Longtube headers
    Borla Atak
    Active exhaust delete
    Hemifever Tuning
    2016 Charger Scat PackLMI Intake3.70 gearsLongtube headersBorla AtakActive exhaust deleteHemifever Tuning
    Likes HandyCharger liked this post
    Oct 2015
    Arkansas
    Thanks for all the help. The car is now at the dealership being fixed under warranty.
    Mar 2018
    East Haven, Connecticut
    Never spray WD40 on a belt as it drys them out rather quickly.
    2017 Redline Red ​T/A 392 Automatic
