Results 1 to 15 of 16
Thread: Should I worry?
    Jun 2016
    Fayetteville NC
    Should I worry?
    Seen this by the water pump, I believe..... should I take heed?
    It’s a ‘16 with about 40K miles... thoughts?
    May 2006
    wisconsin
    its leaking at the gasket put a new pump in it or just keep an eye on it Just put a water pump in my sons Jeep with a Hemi but it has 95,000 on it
    other rides 1969 S/C Rambler, 92 Chevy pick up, 2005 Magnum # 576 Hemi Registry , 2017 Charger Daytona 392 ,1967 Rebel SST
    Thanks ODB thanked for this post
    Likes 392WLCHR liked this post
    Jun 2016
    Fayetteville NC
    Thanks for the reply..... it looks suspect
    Jun 2016
    Fayetteville NC
    I’ll probably clean the engine bay & give a few tugs on the bolts....keep an eye on it for about another 250 - 500 miles or so..
    Likes bgipson21 liked this post
    Jun 2016
    Georgetown, Tx
    Had my water pump replaced at 28-30k.
    2016 Charger Scat Pack
    LMI Intake
    3.70 gears
    Borla Atak
    Active exhaust delete
    Hemifever Tuning
    2016 Charger Scat PackLMI Intake3.70 gearsLongtube headersBorla AtakActive exhaust deleteHemifever Tuning
    Aug 2015
    Should I worry?Should I worry? I have 28561 miles on my 16 scat. Have to take it in for my corrosion on my hood. I am a month out of warranty and hoping FCA will take care of it
    Sent from my SM-G965U using Tapatalk
    Jun 2016
    Georgetown, Tx
    Had to have my hood repainted for corrosion around that same time.
    LMI Intake
    3.70 gears
    Borla Atak
    Hemifever Tuning
    Jun 2016
    Fayetteville NC
    Well I’m going to get another water pump ‘just in case’ and throw it on the shelf.....The next question is: what brand? Mopar oem or Gates?
    Nov 2015
    Eastern NC
    Quote Originally Posted by bgipson21 View Post
    Rust should be warrantied for 5 years/unlimited mileage.
    Previous:
    '17 Camaro 2SS A8
    Mar 2017
    Bedford, Texas
    Quote Originally Posted by SuperSound View Post
    Most likely it was the spot around the hood latch. They did piss poor prep and treatment where the dissimilar metals meet and they all corrode around the latch.
    Likes SuperSound liked this post
    Jun 2016
    Georgetown, Tx
    Mine was on the top of hood above the driver headlight.
    LMI Intake
    3.70 gears
    Borla Atak
    Hemifever Tuning
    Mar 2017
    Bedford, Texas
    Quote Originally Posted by centexcharger View Post
    LMI Intake
    3.70 gears
    Borla Atak
    Hemifever Tuning
    Yeah, that's not normal lol
    Jan 2016
    South Jersey
    I would wipe it down with a towel, then drive it and check in a couple of hours.
    Maybe it rained really hard, and some water got in through the hood scoop?
    2016 Dodge Charger Scat Pack
    Jul 2017
    Update?
    Sent from my Pixel 2 XL using Tapatalk
    Calgary, Alberta
    Quote Originally Posted by ODB View Post
    Why? It's not the water pump. If you want to spend money, get a gasket.
    Likes ODB liked this post
