Page 9 of 11 FirstFirst ... 7891011 LastLast
Results 121 to 135 of 153
  1. #121
    Dec 2016
    Ft. Lauderdale, FL
    clicking noise back.. unreal... now i think I can say it's not the cleaning of matting surfaces nor the lugs, nor the bolts on the rotor as I took care of all three lol....my only guess is something suspension related unless there is still issue with the rotors but I had the 6 piston on my daytona and never heard such a noise....
    '19 Scat Pack F8 Green; '18 Audi SQ5 Daytona Grey '18 Daytona 392; 16 Scat Pack Granite; '15 Durango R/T Blacktop '14 Volvo S60R Rebel Blue; '12 Audi Q5; '10 Mustang; '08 E90 M3; '07 335I Active Autowerks ...
  2. #122
    Jun 2016
    Georgetown, Tx
    Turn the radio up and quit worrying about it. I’ve spent way to much money and time trying to find a sound only to never find it. I’ve just learned to accept that any vehicle these days is going to make some kind of sound. As long as it’s not a squeak. I hate squeaks.
    2016 Charger Scat Pack
    LMI Intake
    3.70 gears
    Borla Atak
    Active exhaust delete
    Hemifever Tuning
    2016 Charger Scat PackLMI Intake3.70 gearsLongtube headersBorla AtakActive exhaust deleteHemifever Tuning
    Likes 392WLCHR, punisher69 liked this post
  3. #123
    Calgary, Alberta
    Quote Originally Posted by centexcharger View Post
    LMI Intake
    3.70 gears
    Borla Atak
    Hemifever Tuning
    This is not bad advice....
    In the past I've called out the meek for complaining about brake squeal or Getrag clutch chatter while turning sharply. The noises are part of the experience (if you fail to understand this - you're not a performance guy). Those who drive supercars know these noises are part of the package / experience (and they pay a sh!tload more than we do for it).
    On the other hand...this problem is interesting. Any theory put forth so far has been a bunch of kaka (when was the last time you saw that in print).
    I'm really curious to find root cause.
  4. #124
    Dec 2007
    Riverside, California
    Truth!
    Ever heard the Ducati dry clutch? Loud as hell, but works flawlessly...
    On the other hand, I'm still puzzled by this. I've heard it on both cars with mileage and cars with dealer plates.
    Purely conjecture, but maybe it is the two piece rotor. Brembo developed what is now referred to as The McLaren Clip to reduce, or eliminate this exact issue. That's what those spring clips are, on our rotors.
    Mine doesn't make any noise. Now, I'm curious to see what happens when I install my new Centric rotors...
    Interesting thread and input, guys.
    Bob
    Lux Technologies - LuX Technologies - Custom Interior Light Mods for Chrysler / Dodge / Jeep Platforms [LX/LC/WK]
    http://www.luxte.ch
    Lux Technologies
  5. #125
    Dec 2016
    Ft. Lauderdale, FL
    LMI Intake
    3.70 gears
    Borla Atak
    Hemifever Tuning
    Good point
  6. #126
    Dec 2016
    Ft. Lauderdale, FL
    Agreed. Very strange and more than worry about noise I want to be sure it’s not causing any damage.
    It is only turning to the right and only the front left wheel. It goes away when I remove the wheel and then comes back. It also started around 4K and why no noise before then? It was about the time I installed the powerstop pads... could there be a relation there somehow?
    Lastly, I had the same brake setup on my 18 Daytona also 2 piece 6 piston rotor with no such noise. I thought they were the same however the 19 ones are not exactly the same as the rotors have less slots... otherwise they seem to be the same and the powerstop pads seemed to fit perfectly even though they couldn’t confirm they would work on the 19 lol
  7. #127
    Dec 2016
    Ft. Lauderdale, FL
    Quote Originally Posted by diboblo View Post
    Truth!
    Bob
    Understood and agreed... it goes away with windows up, radio on, or track mode lol so I can live with it but it’s more curiousity and can I resolve it as it might be something easy.. also to be sure it’s not causing damage as it is loud... I understand a squeal from brake pad is ok on performance car but this is a little scarier sounding
  8. #128
    Dec 2007
    Only scary rhin that runs through my mind, up front, is hub bearings.
    Eeeek.
    Bob
  9. #129
    Dec 2016
    Ft. Lauderdale, FL
    just dont have time to go leave car at dealer for a day but I might bite the bullet next oil change and just bring it there...let them tell me it's "normal" like some of you say however I have a hard time believing this is a normal sound for a performance car, or any car...
  10. #130
    Dec 2016
    Ft. Lauderdale, FL
    car at dealer now, SA says I'm not the only one with this noise and he says a lot of scats have them because of the 2 piece rotor set up... Even though it's probably true, I told him my daytona 2018 had same rotors and never had such noise lol... I have a feeling they aren't fixing it. told there there are TSB's that address it anyways .... it really is true, my last charger had the same 6 pots up front and never made any sounds remotely close to this.... kind of sucks if I have to live with it but it is what it is I guess...
  11. #131
    Dec 2016
    Ft. Lauderdale, FL
    *update... just spoke to my SA and to one of the techs, who has an Indigo scat and his does the same thing... the only TSB that FCA says is to tighten the rotor hat bolts to help... he said he did that and the clicking is still there. when I told him my daytona didn't have this problem with same rotors, they answered with even though they are the same design, a year later the part number could actually be different and some have this problem so don't. the tech said he himself can't fix the noise so it is what it is... I asked him to give me the specs again and I'll jack it up myself and re check or tighten them again myself LOL... maybe we had the wrong spec earlier in this thread? who knows... I guess as long as it's not dangerous or hurting anything, it's not the end of the world
  12. #132
    Oct 2018
    Houston,TX
    2018 here still clicking. I can ignore it but several friends have asked what the sound is.
    2018 Dodge Charger Daytona - Indigo Blue
    Instagram: @aviorHemi
  13. #133
    Dec 2007
    If the rain stops long enough, this weekend, I'll be doing pads & rotors, on my Cat. Curious to see if this manifests with the Centric rotors.
    No noise with the OEM rotors in 52k miles.
    Bob
  14. #134
    Dec 2016
    Ft. Lauderdale, FL
    If the rain stops long enough, this weekend, I'll be doing pads & rotors, on my Cat. Curious to see if this manifests with the Centric rotors.No noise with the OEM rotors in 52k miles. BobLux Technologies - LuX Technologies - Custom Interior Light Mods for Chrysler / Dodge / Jeep Platforms [LX/LC/WK]
    keep us posted.. curious.... dealer claims it's from this particular 2 piece rotor and the only fix they know of that could help is to tighten the rotor hat bolts, otherwise not to worry about it... I'm at peace with it lol.... 54k miles out of the OEM rotors sounds good.. is that with the stock brembo pads the whole time? Are the centric rotors less expensive than the OEM? also what pads do you use with them, semi metalic like the brembos or a carbon ceramic like the powerstops?
  15. #135
    Dec 2007
    Quote Originally Posted by Heat00 View Post
    Doooood... Centric rotors are $235, each! I've seen OEM rotors as much as $1500 each.
    Been running Brembo pads since new. I'm switching to Z26 pads, this time around. Overall, I'm skeptical about them, but we'll see. Ceramics have let me down, on my other SRT Charger, so...
    Those rotor hat bolts are set to a very mild torque spec. DO NOT let them tighten them. They aren't meant to be gorilla tight.
    I'll update this thread, with my results.
    Bob
