Results 1 to 5 of 5
Thread: ESC Light
    Nov 2014
    ESC Light
    I recently had a leak coming from my electronic Power Steering reservoir on my 2013 Dodge Charger R/T. I purchased an reservoir replacement kit from RockAuto. To access the reservoir I had to remove the passenger wheel and fender liner. While changing it, I think I damaged my traction control sensor cable. After putting everything back together I had both the ESC and the ABS light on. I ordered all 4 traction control sensor cables and replaced all 4 of them. After replacing them the ABS light went out, but I still have the ESC light on. I am able to use the cruise control due to the light. Does anyone know what might be wrong, or how it can be reset? I tried serveral recommendations about the sequence of starting the car and rotating the steering wheel to reset the position sensors. At this point I am not sure if it has something to do with my power steering or my traction control sensors. Any have any ideas?
    Sep 2018
    Springfield, MO
    Did you pull any codes or try resetting them with a scanner?
    Nov 2014
    No check engine light, so no codes unless there is some more advanced scan tool.
    Sep 2018
    Springfield, MO
    You would need something to be able to read abs codes, yeah
    Mar 2016
    N. GA
    Following to learn. Tell us about the leak, crack, hole? Tell us about it while you look for the other?
    2013 Dodge Charger R/T Plus 362.63HP/389.58TQ
