Results 1 to 9 of 9
    May 2015
    ABS & Stability Lights ON
    2014 Charger RT 5.7L 29,800 on Odometer. I was shifting gears the other day and the ABS and Stability warning lights came on. Pushing the dash button for the Stability doesn't turn it off. What do I look for? Bad sensor?
    Jan 2019
    My Magnum has them on too. I had it inspected this week (those lights don't fail it) the mechanic suggested a bad sensor, or sensor wire.
    May 2015
    Thanks, gonna take it to my mechanic tomorrow or Monday. He's pretty good, I'll have him check, dealer is the last resort. I doubt this would be covered under warranty.
    Jan 2011
    Calabash, NC
    I killed my battery last week, leaving the door ajar. Charged it, all good except the abs and stability light on also. drove around about 10 miles. it went off and been that way since. I don't think this helps you but those lights do crazy **** sometimes.
    PB 0-60 3.24 MIR Raceway Drag Radials 6/18
    PB 60' 1.472 @ CF9 4/18
    PB ET 1/8 6.911 @ CF9 4/18
    PB MPH 1/8 101.32 @ The Rock 4/19
    PB ET 10.857 @ CF9 4/18
    PB MPH 127.29 @ Atco 11/18
    May 2015
    The owner's manual recommended driving over 38 mph for a while to see if the lights went out before contacting dealer. Dinna work. Thanks for commenting though. I manually shift the tranny because it has a habit of skipping a gear if I ease up on the throttle between shifts in Drive. The check engine light will either come on or sometimes the vehicle would temporarily go into Limp mode before correcting itself. I bumped the shift lever right for the 2-3 shift and that's when the ABS and Stability lights came on.
    May 2015
    Quote Originally Posted by Johnsand View Post
    Stopped by my local mechanic's this AM, he wasn't able to pin point the problem. The commercial code readers don't seem to be very good with Chrysler software, Got a 8 Am appointment on Monday with the dealer. I hope they don't have to jack up the hubcaps and replace everything else.
    May 2015
    Late update. Took car to dealer. Problem diagnosed as a bad rear wheel anti-lock brake sensor. They nicked me $195 for labor and $34.51 for the part. Service rep then said it needed a rear differential service at $148.71 along with having the fuel injectors and throttle body cleaned at $172.95. They threw in a free 100 point safety inspection for free along with a free passenger side air bag sensor on recall. all told I left the dealership $564.78 poorer.
    Jan 2017
    DFW Texas
    Quote Originally Posted by jerryg1018 View Post
    Damn, they got you with the classic "rear end service" and " throttle body clean". Probably didnt need them, but they dealer will gladly do them and take your money.
    Sent from my SM-G960U using Scat Pack Forums mobile app
    2013 Charger Pursuit. 6.4 HEMI swap. 20x9 forged OEM wheels. Atturo AZ850 275 tires. SHR MOD6 valve body. Tan cloth R/T interior swap. 4 piston red Brembos and 3.09 LSD on the way.
    Mar 2017
    Bedford, Texas
    This is for everyone:
    $172 for fuel injector cleaning that gets done every time you put gas in the car is NUTS.
    All good gas has detergents and cleaners in it now. Paying someone else to put running alcohol through a little drip line into the intake is a HUGE waste of money!
