Page 2 of 2 FirstFirst 12
Results 16 to 28 of 28
  1. #16
    Calgary, Alberta
    Quote Originally Posted by robstorredr/t View Post
    I got a guy works at dealership and quoted me 28 or $2900. Can’t remember now. Seems pricey but I really would like to do something like this if there’s good feedback about doing this.
    Sent from my iPad using Scat Pack Forums
    Major cost difference between the two; the 3.92 being significantly less money. Someone on here a while back bought a pallet full of 226mm's from a dealership closure.
  2. #17
    Nov 2013
    South Florida
    That is probably the member MT 426 300. I think he has one left. I bought mine from him and it is arriving tomorrow.
    I am going from a 3.55 to the 3.92 to get some more torque to the ground without touching the engine. Remember your torque that actually hits the pavement is the engine output x transmission gear x read end ratio. The higher the ratio, the more torque in every gear. As long as you can put down the power, more is better for a fun daily driver.
    With improved technology, manufacturers have gone crazy with this concept. Engines have gotten smaller but awd and transmission tech has gotten better. Some of these newer sport SUVs have 1st gear ratios in the 5's and rear end ratios in the 3-3.5 range. When you have 8-10 gears that shift quickly, you can easily have super low gears for awesome acceleration but a very low overdrive gear for comfortable and efficient cruising.
    We are not so lucky with only 5 speeds in the nag1. A lower rear end ratio puts out more power but with less transmission gears to choose from, that comes at the cost of a lower top speed for each gear and different transmission kick down points. I notice that the Nag1 does not downshift if the destination gear will result in an rpm of 5000 or higher. If you are used to kicking down into 2nd at 65 mph with the 3.06, the 3.55 or higher will only go into 3rd. 3rd will have more pull due to the higher ratio but in some setups, depending on engine output and cam profile, there could be a dead spot at a speed which otherwise was fine with a different ratio. If you have a 440 like Hemissary, there would be no dead spots.
    I can send anyone an excel sheet that will compare two ratios and show you exactly what mph and rpm you be in to simulate a new gear before you make a decision. Just PM me if interested.
    If you are running a 1/4 mile race, there are other considerations but for a daily driver that doesn't hit the highway too much, I don't see any downsides.
    After I went with the 3.55, I was having traction issues until I widened my wheels and used only very good tires. I also switched to a cam that provided some more top end at the expense of a bit of low end. That turned out to be a good combo with a steeper gear by balancing out low end power to actually gain traction and use the gearing on the bottom end to do the work, then once the cam's optimal rpm was reached, the top end pull continues. Unlike an engine mod that has a certain peak power increase, the torque benefit from gearing is felt at every rpm.
    2006 300c SRT8
    PWR Ported Heads | HHP Stage 2R Cam | 3.55 Getrag | GTP Ported Intake Manifold | Kooks Longtubes | Corsa Sport / SRT Resonators | AMG 8 Piston Brake Calipers | Hemituner 6,800 TCM | BT Catch Can | LMI True CAI V2 | Tranzformer | MM 87mm TB | Johan Tuned | REM Adjustable Endlinks & Front/Rear Shock Braces | 33/22mm Front/Rear Sway Bars | Michelin Pilot Sport 4 315/35/20 & 275/40/20 | 10" Widened Oem Wheels | LC-2 Wideband Analog Output to Trinity | Mishimoto Full Aluminum Radiator
    Thanks robstorredr/t thanked for this post
  3. #18
    May 2014
    Virginia Beach, VA
    Your first gear will be fine with shorter gears (numerically higher). There are cars with way more torque than ours running old ass torqflites and 727s with 4.10s or more and they hook up.
    The people who say "first gear will be useless" are full of it. They can't drive. Don't listen to those grannies.
    The 15+ 6.4s have both more torque AND more first gear than your car, and they hook up. Traction is a function of driver mod first, and tires second. I can hook up first gear in my 70 Charger with a 580" big block, a hemi four speed, and 4.10s out back (that's 11.5x gear multiplication being turned by 700ft/lbs of torque).
    I just put 3.91s in my heads/cam RT, and the only thing I wish I had now is MORE TORQUE! Don't fear the gear.
    Sent from my SAMSUNG-SM-N900A using Scat Pack Forums mobile app
    2006 Dodge Charger Daytona TorRed #1354, SRT Heads/Intake - ARH Long Tubes - Spartan Plus Cam - Magnaflow - 3.91s - 411rwhp/410rwtq
    Acceleration video: https://www.youtube.com/watch?v=MLey...aubWU9N6ezVy7g
    I detail cars in the Virginia Beach/Norfolk area! 757-435-4027
    Thanks BM_SRT thanked for this post
    Likes Hemissary, BM_SRT liked this post
  4. #19
    Nov 2013
    South Florida
    Quote Originally Posted by Beach Goat View Post
    Two things that helped drastically with 1st gear, other than better tires:
    1. If you have throttle boost enabled on your tuner, turn it back to zero. That will give your more "resolution" to be able to modulate the throttle better, versus having the booster setting multiply your input.
    2. Hit the traction control button to turn it off. Maybe its just my vehicle but the traction control initiates an artificial loss off traction when I get into the throttle a bit in 1st. It felt like I hit some ice but its the middle of summer in Florida. Turning it off by just hitting the button once helped a lot. The rear end still gets a bit loose but at least it stays straight and power is delivered properly.
  5. #20
    May 2014
    Virginia Beach, VA
    Quote Originally Posted by BM_SRT View Post
    Very good points! I forgot about that, I have the throttle boost actually set to negative half a percent after the heads/cam and 3.91s. It gives me much more throttle control. Anither positive byproduct is the engine actually feels more responsive, and like it always has more power to give.
    It's kind of hard to explain....but I'll try.
    With the throttle boost way up, it felt like I would reach WOT, and therfore maximum acceleration, at like half throttle. Then even if I pushed the pedal more, I didn't get more power. Now, every single little movement of the pedal equates to more and more power, all the way up to 100% WOT.
    And I've also noticed that the ESP is a little out of its league with all the torque hitting the tires now. It'll pull back power to regain traction, but then it'll throw it all back in making the tires spin again. I prefer turning it off now and sorting the traction out myself.
  6. #21
    Jun 2007
    Scottsburg, IN
    I’d like that excel sheet
    Rob
    Current Ride - 2012 Dodge Charger 392 SuperBee - Yellow
    2014 Dodge Challenger - HederOrange, R/T Blacktop Edition - Sold
    2006 Dodge Charger Daytona 5.7L - Torred - Sold
    Mods: Diablosport Intune
    Performance: TBD
  7. #22
    Nov 2013
    South Florida
    Ok PM me you email, thanks.
  8. #23
    Calgary, Alberta
    Given different rear gear ratios available, max rpm and applied tire diameter (need to enter your specifics), here's a Gear Ratio Calculator.
    NAG1 transmission ratios to enter:
    1st: 3.59
    2nd: 2.19
    3rd: 1.41
    4th: 1.00
    5th: 0.83
  9. #24
    Jan 2006
    Kingsport, TN
    Yes. my Challenger had the 3.06. Big difference coming from the 3.06 to the 3.73.
  10. #25
    Jun 2007
    Jackson, MS
    I’d love to see it too. Can you load as a snapshot on this post?
    SCOTT57RT
    2007 RT Charger 5.7L - Black Crystal Pearl
    Mods: DiabloSport Predator - InertiaTuned, MagnaFlow CAT Back Exhaust, JBA High Flow Cats, JBA Headers, 185Tstat, 85mm CNC Throttle Body, 6psi-P1SC Procharger Supercharger, Blown Spartan Cam, 20x9 FR SRT8 Challenger Wheels/Nitto555G2, Mygig, BC Racing Coilovers, Willwood Brakes&Rotors, 3.06 Getrag
  11. #26
    Jun 2007
    Scottsburg, IN
    Who are "they"?
    "They" are the same worry-warts I was referring to above...emotionally driven that the engine is somehow being "over-revved" :^)
    Just people on forums and such.....
  12. #27
    Nov 2013
    South Florida
    Quote Originally Posted by SCOTT57RT View Post
    Sure, what two gears do you want to see compared?
  13. #28
    Nov 2013
    South Florida
    Here are a few comparisons:
