Key FOB program on Autel MaxiDas DS708
8K views 3 replies 3 participants last post by  Rockhound
#1 ·
Is it possible to program a new Key FOB with the Autel MaxiDAS DS708? From what I see online, it seems to work with anything but my car.
Wife had her Key FOB fall out of her pocket at 6 Flags. The Key FOB was destroyed, but recovered. I purchased a new replacement on Ebay, but I cannot find how to program it. I see videos of how easily it works on other cars, but when I go the the same folders on the machine, the key FOB doesn't come up anywhere. I'm supposed to be able to program a new Key FOB with this scan tool. I'm trying to do this with my 2011 Charger RT. I could not find anything on here already for this.
Thank you.
Mark
#4 · (Edited)
I have the same Autel Scanner. I haven't tried to do a fob yet with it. I am not sure it can do fobs. On older Chryslers it can do keys, if you know the skim code. I never saw a function for RKE programming since it is a separate module. I presume the same is true on the CAN bus cars too. However since the RKE is now integrated into the skim module, the combined module now called SKREEM, it may be that it can do the fobs too. I have a broken leg so I am a bit immobile now so I cannot go outside and play with the car to see if I can find a fob function or not in the DS708. If you find out the answer let me know.
On the older cars with a separate RKE, if you had one working fob, you could program more fobs by entering the programming mode after pressing the correct sequence of buttons. I suspect it is the same on these Canbus cars too. Do you have another fob available?
