Results 1 to 5 of 5
    Jul 2021
    315/35/r20 on 20x10.5 - 20mm offset on 2010 Charger SRT8...
    First off...YES....I have searched and read the forums for answers at length. I have not been able to find pictures or examples of the above mentioned combo.
    Anything I've found was "largest tire on stock wheel" type of questions/answers.
    Any of the calculations I've been doing seem to indicate that a 20x10.5 - 20mm offset may have clearance issues or will protrude outside of the fender well.
    Numbers on paper don't always indicate what the actual outcomes are so I was hoping someone had examples of a 20x10.5 with a 295/40r20 or 315/35/r20 on a 2006-2010 Charger SRT. I am able to find examples of this tire combo on the newer Gen Chargers....but nothing in this year range.
    Part of the problem is that tire shops around will not bring tires in to test mount...they say once the tire has been mounted...it cannot be returned....ergo my dilemma
    Any help is greatly appreciated!
    Mar 2017
    Bedford, Texas
    +20mm offset you'll be fine. If it's -20 (as you typed) it won't work. That'll stick waaaay out from the fender.
    Jul 2021
    Ha ha...thanks for the reply! That was supposed to be a hyphen ( - ) not a -20 offset.
    Dec 2016
    20x10.5 +22. 315/35R20 nitto nt555 g2 on rear & 20x9.5 +15 275/40R20 front on my 2008 it’s also sitting on mopar stage 1 springs
    Likes Renfrick1 liked this post
    Jul 2021
    Thank you! Your pictures have restored some faith that they should fit. Will post pictures once they are mounted up and test fitted on the car.
