Results 1 to 15 of 16
    Sep 2018
    09 Charger 3.5L won't shift from 1st
    So my daughter's car all of a sudden stopped shifting out of 1st gear. Starts fine, runs fine, just will not shift.
    I can give it all the gas that I want, and RPMs rise accordingly, just will not shift.
    No codes.
    If it matters, I recently replaced the EGR valve, in which I removed the plenum, as well as the throttle body. Did that about a week ago, and it has ran fine, until.
    Please help!!!
    Central Florida
    I'm guessing it's
    in manual mode. Press the shiftier to the passenger side (right( to disengage it.
    Old 426 guy,
    Jim
    Sep 2018
    Quote Originally Posted by Jim McVeigh View Post
    I'm guessing it's
    Funny you say that, because I didn't think the car had the manual shift, but I tried last night, to confirm, and it doesn't.
    Sep 2018
    Springfield, MO
    Well, any check engine lights? Did you plug everything back in properly? And are you double sure?
    Sep 2018
    No check engine light. I did double check last night, and everything is plugged in, and seated good. Not sure if it's just a coincidence or not.
    Bad timing for sure though, lol
    Jan 2011
    Calabash, NC
    not sure if 3.5's get limp mode, but my 09 RT did that when i changed a few things way back.
    PB 0-60 3.24 MIR Raceway Drag Radials 6/18
    PB 60' 1.472 @ CF9 4/18
    PB ET 1/8 6.911 @ CF9 4/18
    PB MPH 1/8 101.32 @ The Rock 4/19
    PB ET 10.857 @ CF9 4/18
    PB MPH 127.29 @ Atco 11/18
    Sep 2018
    Springfield, MO
    We do
    Jun 2015
    Southern Connecticut
    So you've got a 42RLE 4-speed?
    When you say "no codes", did you scan with a scantool that can read pending DTCs?
    "Many true sports cars can be outrun by a powerful sedan." - Sir William Lyons, Chairman, British Leyland
    Sep 2018
    Springfield, MO
    It doesn't exactly sound like he's having transmission issues or limp mode, but since he mentions taking off the intake: the only thing I can think of is that he did not properly seat the EGR tube into the back of the intake. Which is an issue I actually had one time like this.
    Jan 2018
    Pueblo West, Colorado
    Quote Originally Posted by Kdp919200 View Post
    Do you have a scanner with the ability to check for codes in multiple modules? Transmission might have a code that's not throwing the CEL. If you don't have one, the AlfaOBD app lets you check each module separately for codes, it costs $50 and you need to buy a Bluetooth adapter, but well worth it!
    You might try disconnecting the battery and tying the battery leads together for 30 minutes or so to reset everything completely.
    Sent from my SM-N950U using Tapatalk
    Jan 2011
    Calabash, NC
    oh crap, the other time i had that problem it was when the 'cone ? ring" on the axle was damaged. if it is the car will not shift.
    Help me its the ring on the axle... i think .. never mind i can't remember the correct name. tone ring
    car would not shift until it was fixed.replaced. hope i helps.
    Tone ring..
    Nov 2010
    That just happened on my ram
    New tranny
    Likes Jay Z liked this post
    Sep 2018
    (UPDATE) EGR tube is seated good. Saw a couple of possibilities that a bad PCM will cause some of the same symptoms. No luck. Actually runs better, but still no shift.
    Sep 2018
    Quote Originally Posted by JD323 View Post
    No sir I don't. I'll unhook the battery and try that
    Sep 2018
    Ok. Reset all the codes, and now have one!
    P0750 - Shift Solenoid A
    Its in the pan, so i'll swap it out this evening, with new fluid.
    Really noob question, sorry:
    What is the difference between 1st gear in "D" and putting the car in "L" or "3" ?
    Reason I ask is when I put the car is "D", it shifts and feels like I have put it in one of the lower gears.
