Results 1 to 14 of 14
Thread: Rear end noise
    May 2018
    Rear end noise
    Hello all,
    I've got a noise coming from the passenger side rear of my 2010 Charger AWD R/T. It's got 110K miles on it. I've had the rear brakes replaced (calipers, rotors and pads). The wheel bearings have been inspected and they are fine. My mechanic replaced the fluid in the rear diff with synthetic, which did quiet the noise down a little but it is still there. He mentioned it may be the pinion bearing. Has anyone here ever done that job? I did a search but didn't find anything on it. Is it something I could do myself to save some money? My mechanic want's $400 to do it. I would really appreciate any information you have. It's not really loud, but I don't like hearing unusual noises.
    Thanks,
    KrustyTC63
    Jan 2011
    Calabash, NC
    i had a groaning noise, especially when just starting out and turning, had the diff(LSD) lube changed to spec . the noise was better then finally went away.
    PB 0-60 3.24 MIR Raceway Drag Radials 6/18
    PB 60' 1.472 @ CF9 4/18
    PB ET 1/8 6.911 @ CF9 4/18
    PB MPH 1/8 101.32 @ The Rock 4/19
    PB ET 10.857 @ CF9 4/18
    PB MPH 127.29 @ Atco 11/18
    May 2018
    This is almost like a whistling noise. It will stop when I take my foot off the gas, then come back when I accelerate.
    KrustyTC63
    May 2015
    Louisiana
    Sounds like the familiar rear end whine and it's probably from the gears themselves. An oil change usually quiets it slightly but never fixes it. Don't know if he can fix it for what you can swap in a new rear for.
    Mar 2019
    It’s your ring an pinion gears going out. That symptom is almost exclusive to the ring and pinion gears in your rear end
    Mar 2019
    When they went out on my girlfriends truck i just got a whole axle assembly from the junkyard and it was about $400 cheaper than getting the rear end rebuilt
    May 2018
    What does it cost to have the rear end rebuilt? I'm just looking for a ball park.
    Thank you all for the information,
    KrustyTC63
    May 2018
    Just trying to bump this up, does anyone have a ballpark cost to having the rear end rebuilt? My mechanic believes it is the pinion bearing. It sounds to me like it is exclusively coming from the rear passenger side of the car.
    Thanks again,
    KrustyTC63
    Mar 2019
    Probably about $600 to $800 depending on labor costs. I would get a complete axle from the junkyard for in between 500-600 and swap it in
    Calgary, Alberta
    Quote Originally Posted by KrustyTC63 View Post
    Hello all,
    Thanks,
    KrustyTC63
    Unless there's an anomaly that's been present since new that is now presenting itself, it is extremely unlikely it is the bearings or gear interface.
    Did / does it leak fluid - at all?
    Is it the OEM unit?
    May 2018
    Is it the OEM unit?
    It does not leak fluid and it is the OEM unit.
    Calgary, Alberta
    Have you altered any of the rear suspension?
    Did the noise just appear or come on gradually?
    Has there been any noise - all along?
    Have someone drive while you sit on the passenger seat, then the rear, both sides listening carefully to isolate...
    May 2018
    Have you altered any of the rear suspension? No
    Did the noise just appear or come on gradually? Just appeared
    Has there been any noise - all along? No
    Have someone drive while you sit on the passenger seat, then rear listening carefully to isolate... I will do that at some point this weekend
    Thank you very much for your time and input.
    May 2018
    So, the fluid in the rear end has been swapped with synthetic. The noise is still there, but not as bad. It sounds to me like the only fix is to replace the rear end. I'll start trying to find a replacement. Is it a hard job to do yourself, or would I be better off having my mechanic do the job?
    later,
    KrustyTC63
