Results 1 to 15 of 15
    Mar 2018
    Fairview Heights, Il
    LX Need some NAG1 clarification
    Hey fello Dodge owners I drive a 07 Charger srt8
    i need some clarification on the nag1, I’ve been having some trans problems for a while now and recently (about a week ago) the torque converter lock up has stop working. Still driving the car now but babying her I plan on just doing a complete rebuild
    I’ve looked into a transtar 78006D rebuild kit and torque converter
    my problem is the valve body, what I need clarification on is are the valve bodies on all the nag1 transmissions the same?? I know the DX has the ability to paddle shift and my LX does not but surly that doesnt mean the valve bodies are different or the solenoids are different?
    Sep 2018
    Springfield, MO
    Supposedly the "srt8 nag1" has tougher clutch bands or something but I'm not 100% in that...the VB and solenoids are the same unless you get the Mercedes blue tops for these which just make it feel firmer during shifting, nothing really for performance. Do you get any codes for this issue your having? Limp mode? Or is it just slipping during shifts some or all the time?
    Jul 2019
    Quote Originally Posted by Dsbiker01 View Post
    You need a rebuild kit specifically for a Mercedes NAG1/722.6/W5A580 That is in a Dodge vehicle. And that Transtar kit isn't the greatest.
    I WOULD NOT swap the valve body. The Paddle shift ability is built into the vehicle, not the transmission.
    Mar 2018
    I am throwing a code it’s the P0741 torque converter performance stuck off, and it’s thrown another too for incorrect gear ratio.
    since the P0741 came on the the surging has stopped at highway speeds( since its not locking anymore) only mods to her now are CAI, cat back, Diablo tune T2 Trinity, Mopar performance TCU
    Mar 2018
    Looking for a good site for a rebuild kit then, any idea? just Oem style, I’m saving for gearstar just need to keep her running
    Jan 2016
    Are you doing the rebuild yourself? There are alot of special tools needed.
    Jul 2019
    I'd drop the pan and look for debris in the pan, and break open the filter and look inside it. If it doesn't have a bunch of garbage in it you don't need a rebuild. It could be the conductor plate.
    This isn't a bad kit here. 722.6 Rebuild Kit NAG1 W5A580 Mercedes-Benz Automatic Transmission Master Overhaul Banner Dodge Jeep: Oregon Performance Transmission
    I would tear it down before ordering parts. Don't order what you don't need. These transmissions hold up very well, you're probably not dealing with a meltdown here.
    Sep 2018
    Springfield, MO
    Also are you sure you didn't just get water in it? The nag1 hates water, even as little as like 0.5% total fluid volume
    Mar 2014
    FL
    Something worth trying before going with a full rebuild is to try changing the conductor plate. It's a common failure and it controls the whole transmission.
    I had a complete failure and ended up changing it and it's fixed everything so far.
    I documented it here. It's only a few hours of time and about $100-$120 in parts and fluid. and well worth a try.
    How I saved the transmission in my SRT8 300's! - YouTube
    My 2 Ton Beast
    2007 Black 300 SRT8
    Procharged
    Youtube Channel
    https://www.youtube.com/channel/UCo3...llSevp9qnpN6Q/
    Mar 2016
    DE
    Which code came first?
    Mar 2018
    I would agree 100%, the but is I’ve had the pan down a couple times both times the magnets were covered and the second time the filter was dropping out a metallic material and fluid was black
    the hope is that the valve body and or torque converter clutch took a dump and that’s the material I saw. The trans shop I took it to said it was having a valve body problem that was affecting the torque converter lock up.
    Car still shifts gears 1-5 ok but before the code P0741 it was surging in 4&5 making me think clutch slip and now since the code it shifts fine with no surge so I hope converter clutch bad and valve body is it
    my thinking is if I tear down and inspect then the work is done just rebuild it all and be done, maybe I’m over thinking it
    Mar 2018
    P0730 first a while ago then about 2weeks ago P0741 showed up and converter hasn’t locked up since
    Corona, CA
    Want to know more?
    Power flow..
    Chrysler NAG1 5-Speed Transmission Power Flow - YouTube
    Tear Down and inspection...
    722.6 Mercedes Transmission, Teardown Inspection - YouTube
    More info on valve body..
    722.6 valve body - YouTube
    You Tube is full of info on the Nag1 (722.6 Mercedes transmission)
    2006 Charger SRT8
    MPR Motorsports built 6.1 based/392 NA Stroker, BBK 85mm TB, TranZformer, Kooks Long Tubes
    Jan 2016
    I would seriously consider a used trans from a place like LKQ. I got a used one from them and installed Alto clutches and seal kit from my dealer. I had to dig out a lot of special tools to rebuild all the clutch packs. The inside of the used trans was mint. I only beefed it up because it was getting a Procharger.
    Likes Ultimagic5 liked this post
    Jun 2012
    West Texas
    Diablo tune T2 Trinity - Check your tune and make sure that your still showing the correct gear ratio being installed.
    Mopar performance TCU - Same as above check to see if the ratio is correct for what you have installed. I replaced my T1 with a T2.... I also have the MTCM. However, the T2 did change my ratio on me atleast once. Id get the same gear ratio code. The vehicle would run if i babied it but..... If you got on it it would limp mode until you reset the vehicle.
